very very bad seeing ... but with lots of post processing managed to get something out.
80mm f/6 + Quark - ASI120MM-S
And one of the proms
The following ones would normally go to the bin. Taken with the C8. But just to show some small spots (or just darker cells?) in that area from first image. Still most sources are reporting now 20 spotless days. How big does a spot need to be before it counts?
Edit: seems these are called "penumbral spots". If so then they can't be used to calculate the Wolf number.
White Light - AstroSolar ND 5 (still seeking some ND 3.8 in that size)
Solar Continuum - AstroSolar ND 5
Paul
Another from 14th of July
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: Another from 14th of July
Pity about the conditions, Paul. Good captures in bad seeing.
- Has thanked: 20424 times
- Been thanked: 10243 times
Good captures given the conditions Paul!
- Has thanked: 17666 times
- Been thanked: 8787 times
Fantastic pics Paul, glad to see you back
I think these are pores, they need to have a penumbra to be called a spot.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
some seem to call these "spots" depending on the length of time they are visible (If you go to spaceweather history on 14th and 15th and zoom in, there was something there on those 2 days). But will not argue about the naming, not enough knowlegde.I think these are pores
Thanks for the comments Stu, Mark & Alexandra.
P.
- Has thanked: 9144 times
- Been thanked: 6025 times
- Been thanked: 4904 times
