Large Filament | 150mm & Quark | 6562.8A | July 24th 2018
- Has thanked: 1188 times
- Been thanked: 1382 times
Hey all,
Been a while, it's currently raining. It's been days, if not nearly 2 weeks, since I've been able to do much other than dodge rain going in and out for work. Of course, the first day I wake up to a cloudy, but not raining morning, with potential sucker holes to shoot through. I have a new-to-me refractor to try, picked up a 150mm F8 doublet achromat for dirt cheap here on the forum. Shows a ton of CA at night with visual in visible spectrum. But it's fantastic in ultra-narrowband. Today was my first use with it and I did both visual & imaged for about 2 minutes before the rain started. Visually it was bright, contrasty, looked great. Imaging wise, I could notably feel the new limits of seeing on 5040mm effective focal length, but the seeing supported me looking at some surface spicules and the big filament currently present. There were two faint prominences on the limb, which I could make out fine, but they were not worth imaging at the time, so I pointed it at the filament. Not my norm, as I usually am all about prominences more than anything when there's not a sunspot around.
Equipment:
Celestron (6 inch) 150mm F8 Refractor + 80mm, 80mm & 50mm extensions with Baader UV/IR block filter (ERF) with GSO Focuser (upgrade from stock)
Quark Chromosphere
ZWO Tilt Adapter (wasn't needed, but I always have it on)
ZWO ASI174MM Camera
SharpCap (acquisition) | Autostakkert!2 (calibrate, stack) | IMPPG (deconvolution) | CS5.1 (final processign) | Best 351 out of 3,000 Frames
Astrobin:
Equipment:
Quark Chromosphere
ZWO ASI174MM Camera
Astrobin:
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Re: Large Filament | 150mm & Quark | 6562.8A | July 24th 2018
Looks great! My seeing has been just the worst recently, and the 110F temps don't help either - Quark won't stay on band. Why is astronomical equipment painted black?!? Everything is painfully hot to touch and the bubble level on the Mach1 seems to have boiled off. Time to drop back to the Lunt for a spell.
Dunno why everything is black, I guess most of it is intended for night use.
Doesn't bother me, either way. I generally only spend a few minutes in the sun. If I were doing an extended couple-hour-session, I'd just throw my reflective solar cover on there (big enough to cover a C14 & mount, I use it all the time when the mount's not in use).
- Has thanked: 174 times
- Been thanked: 619 times
Interesting comment re the Quark...here in Australia we regularly get temperatures in the 40 deg C....
I could not get confirmation from Daystar that the quark would function in elevated temperatures......
- Been thanked: 4427 times
Hi Marty...
An excellent capture of the filament...well done!!!
I use the same Celestron OTA as my donor scope for the Lunt mod...they do work well in the narrow bands for solar. I see you had to put a lot of spacers in tho the the Quark to focus...took the mages to get the spacing figured out when I was testing out a friends Quark
- Has thanked: 8558 times
- Been thanked: 8290 times
Very nice filament images, Marty.
- Has thanked: 20813 times
- Been thanked: 10485 times
Great results Marty and a nice new toy!
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Excellent !
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
- Been thanked: 4980 times
Marty:
Super shot and a nice scope.
These are superb images, what a great first light
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Super stuff - really detailed & dynamic image - must be pleased with its debut!
