Today's SUN (2018078) | HR granulation (TEC140)
- pedro
- Has thanked: 14 times
- Been thanked: 6748 times
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2018-07.html
Check out a few HR WL images taken with the TEC140 with good seeing. Got the SSM plugin working with Firecapture 2.6
Solar Imaging Session (20180728) | Pedro RE'
TEC140, TV101, GS3-U3-28S4M
WL HR granulation
Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
SUN (20180728) WL. TEC140 F/7, X5 Powermate, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180728) WL. TEC140 F/7, X2.5 Powermate, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180728) H-alpha DISK & PROMS (08:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180728) CaK PROMS (08:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20180728) WL, CaK & H-alpha (08:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
WEBLINK:
WL HR granulation
Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
Pedro Re'
- robert
- Has thanked: 4 times
- Been thanked: 1284 times
Re: Today's SUN (2018078) | HR granulation (TEC140)
Great shots. I like the granulation
Robert
Robert
- pedro
Thanks Robert
I'm uploading a youtube video with more info
Pedro Re'
- Has thanked: 65 times
- Been thanked: 4459 times
Hi Pedro...
Nice sharp full disk images and the granulation jumps out as you go to longer focal lengths. Well done
- pedro
Thanks again Brian
Pedro Re'
- Been thanked: 171 times
Pedro that 140mm is an optimal size for granulation.
- pedro
Thanks Derek
You're absolutely right, it is a great match for the seeing I have most of the times
Pedro Re'
- Has thanked: 20940 times
- Been thanked: 10587 times
You've got some excellent images there Pedro, and some excellent seeing too. Here's my graph from friday morning waiting for the clouds to break:
ssm by Mark Townley, on Flickr
I think you could probably be a bit harder on your capture settings with the SSM given your excellent seeing; i'd try trigger limit of 1" and cutoff threshold of 1.5", I still think you would get a decent amount of data to work from. What does the quality graph look like with the 5x powermate shots?
- pedro
Thanks Mark
Here are a few images of my screen while using the X5 powermate. I used a trigger limit of 2"
- screen_20180728-12.jpg (594.85 KiB) Viewed 2087 times
- screen_20180728-13.jpg (564.18 KiB) Viewed 2087 times
- screen_20180728-14.jpg (567.87 KiB) Viewed 2087 times
- screen_20180728-15.jpg (560.49 KiB) Viewed 2087 times
- screen_20180728-16.jpg (619.24 KiB) Viewed 2087 times
- screen_20180728-17.jpg (667.86 KiB) Viewed 2087 times
- CHART_ssm_20180728-01.jpg (278.06 KiB) Viewed 2087 times
Pedro Re'
- Been thanked: 1390 times
- pedro
Thanks Marty
Pedro Re'
- Has thanked: 8588 times
- Been thanked: 8324 times
Excellent set of images, Pedro. Those granulation shots really do 'pop'.
Between you and Mark, I'm now convinced that I should try auto imaging based on SSM input.
- Has thanked: 18101 times
- Been thanked: 8938 times
Really enjoyed the granulation shots Pedro interesting to see the screen shots too.
