Heya,
Woke up to a cloudy, but blue sky. I don't mind shooting through sucker holes! Managed some decent seeing at smaller scales. At my largest scale, it was challenging to get workable data as the seeing just wouldn't support the focal length. I dropped my scale with a 0.5x focal reducer and managed to get much better data. Then shot at my lowest scale to compare. Then as seeing seemed a little below average, I shot some data at my largest scale again just to see if I could get lucky on a few frames and managed something, but it's far from what I would have wanted normally. I'll take it though. This summer has been awful for anything weather and sky related here in Florida.
Equipment:
Scale 1: Celestron 152mm F8 Refractor + UV/IR cut filter + 210mm Extensions + 0.5x Focal Reducer
Scale 2: Orion 80mm F5 refractor (masked to 60mm F6.666) + UV/IR cut Filter + 130mm Exensions
Scale 3: Celestron 152mm F8 Refractor + UV/IR cut filter + 210mm Extensions (No Focal Reducer)
Daystar Quark Chromosphere
ASI174MM Camera
Colored:
Scale 1:
Scale 2:
Scale 3:
B&W:
Scale 1:
Scale 2:
Scale 3:
Active Region 2717 & Prominences | 60mm & 150mm | Aug 3rd 2018
- Been thanked: 1390 times
- Has thanked: 9379 times
- Been thanked: 6198 times
Re: Active Region 2717 & Prominences | 60mm & 150mm | Aug 3rd 2018
Excellent results, Marty. Those prominences are cracking..
- Has thanked: 65 times
- Been thanked: 4453 times
Excellent results Marty
- Has thanked: 18090 times
- Been thanked: 8934 times
Yes, really enjoyed these proms
