August 5th - Part 2
August 5th - Part 2
Post by MapleRidge » Tue Aug 07, 2018 1:40 am
Hi all...
It took a few hours this afternoon to finish processing the balance of the images collected of Sunday. As mentioned in the first post I had a set imaged through the 5x Powermate, but I also had some Ha sets that were imaged in the red and blue wings. I'll start with the 5x series, taken through the modded CR150/DSII/B1800Ha + 5x Powermate + ZWO174MM camera
The first region was the emerging active region on the eastern limb, first imaged with the DSII etalon set at 0 PSI which shows a wide Ha band:
The next series have the etalon tuned to the midpoint of the Ha:
The image below is the remains of AR2717 with the tuned etalon (my continuum image did not work out):
The following images used the same setup, but with a 3x tele-converter. I adjusted the pressure in the DSII etalon to image the red and blue wings of the Ha line. Each region is shown in the following order...Red Wing/On-Band/Blue Wing, starting on the eastern limb:
The last region is the remains of AR2717:
This should finish off the session from Sunday. Another round to process from today, but they will be a few days before they are all processed and posted.
Re: August 5th - Part 2
Post by Carbon60 » Tue Aug 07, 2018 5:52 am
A great set of images, Brian. You had a very busy session.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by Montana » Tue Aug 07, 2018 9:13 am
Another great set, I like the wing comparisons a lot. I always forget to do this and yet it is always interesting when I see others do it.
:bow
Post by ffellah » Tue Aug 07, 2018 11:32 am
A very nice follow-up set, Brian ! The inverted Ha is very 3D..
Post by Valery » Tue Aug 07, 2018 2:28 pm
Nice session, Brian!
Hope you will have many clear sunny days with a good seeing like this one.
Post by marktownley » Tue Aug 07, 2018 8:27 pm
Loving all this imaging you're getting in Brian!
Post by MapleRidge » Wed Aug 08, 2018 1:23 am
Stu, Alexandra, Franco, Valery, and Mark...
Many thanks to each of you for the comments and feedback...always appreciated :bow
Users browsing this forum: banjo, David_The_Bears_Fan and 4 guests
