ISS Transit August 7
PDB
Post by PDB » Tue Aug 07, 2018 6:12 pm
Not much to see on the Sun, but an ISS transit late afternoon. Whole day Sunshine, then clouds started to form and 1 minute before the transit the Sun was still obscured by a thick cloud. Then suddenly it cleared, 1 second transit and a few seconds later another cloud dimmed the image.
Because of all the clouds, no time to adjust the camera in the correct position.
Cadence of the image was not really correct (and using the ASI178 wit 6.4 Mpixel at around 70 fps, a few gaps occured in the capture. In the final assembly I skipped a frame every 2 frames (approx) so it looks a little bit better than the full capture.
this is how the "full" capture looked. Clearly shows the camera "hick-up
Paul
Re: ISS Transit August 7
Post by marktownley » Tue Aug 07, 2018 8:37 pm
That's brilliant Paul!
Post by ffellah » Wed Aug 08, 2018 12:36 am
I am sure it was challenging but the final result looks great, Paul
Ibbo
Post by Ibbo » Wed Aug 08, 2018 1:22 am
Thats a cracker :band
Post by Carbon60 » Wed Aug 08, 2018 5:48 am
A very fine capture. I'd love to capture one of these transits myself sometime. So much has to come together at the same time.
Quite a challenge. Well done.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
PDB
Post by PDB » Wed Aug 08, 2018 7:10 am
Thanks,
well you need some things (and luck) coming together.
- A transit needs to happen
- Needs to be a good one, with ISS close to earth
- Weather
- Preparation
Preparation could have been better. As you can see from the detail (100% crop) at full resolution, there is still room for improvement
Paul
Post by Montana » Wed Aug 08, 2018 11:31 am
:hamster: sounds like what happens to me every transit except I get it the other way round ;)
Well done!! what a great catch :bow
Albuqshutterbug
Post by Albuqshutterbug » Wed Aug 08, 2018 4:57 pm
I’ve managed to capture 3 solar and 1 lunar transit in the past year.
Your zoomed in shot is really nice.
Was it the clouds that caused your hiccup or just an anomaly?
I think it adds character to the image.
Nicely done.
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
robert
Post by robert » Wed Aug 08, 2018 4:59 pm
Very nice indeed!
Robert
PDB
Post by PDB » Wed Aug 08, 2018 5:17 pm
Thanks Alexandra, Jim and Robert.
Not the clouds. I had set the camera to high-speed mode to allow faster capture rates. That seemed to be a mistake. The ASI-178 has 3096*2080 pixels, so that puts a lot of stress on the USB 3 and cpu. I have a very fast PCI M2 ssd in that machine so writing the data should not be the problem. At high speed with that cam I see frame rate around 59 fps but occasionaly it drops slightly for a moment, so that is where I get the delays. (Should do a check from the timestamps in the SER file) Actually I was very lucky, because frame rate was almost to high and images were almost overlapping. Should have checked that on beforehand, but ...
Paul
