Ha Quantum filter PE 0.4Å
Has thanked: 156 times
Been thanked: 893 times
Re: Ha Quantum filter PE 0.4Å
Post by Valery »
marktownley wrote: Mon Aug 13, 2018 3:11 pm
rsfoto wrote: Mon Aug 13, 2018 2:49 pm
About temperature that is the next problem. I saw yesterday that in my area it is taking long time to cool down or nearly it does not cool down. I think I will have to add some fans to cool it down. Yesterday the Quantum remained for a very long time at 6563.0Å and the light was yellow. I had it adjusted to 6562.8Å.
As of now it is cloudy so I will look for some ideas how to add a fan to the Quantum.
That's the problem with Daystars (compared to Solar Spectrum) - no active cooling. My Quark drifts off band with the heat if I leave it a while...
All my Quarks were stayed at the CWL no matter how long I use them for imaging. Even when I leave the telescope for an hour or two being tracking the sun.
Mark, do I understand correctly that if you adjusted your present Quark to the CWL, after a while it will change it's CWL transmission to the red (increased temp) ?
Has thanked: 20819 times
Been thanked: 10489 times
It only drifts off on the HaT, after several hours Valery, and that has only been this summer when ambient temperatures have been 25c+ outside whilst imaging.
Post by Valery »
Rainer,
According to Mark Wagner, who produce Solar Spectrum etalons (very much like DayStar does) the only correct ERF filter for such etalons is at least a red filter. The less unwanted heat from the sun will reach an etalon, the better etalon keeps it's position at a choosed wave length.
Post by Valery »
marktownley wrote: Mon Aug 13, 2018 3:56 pm It only drifts off on the HaT, after several hours Valery, and that has only been this summer when ambient temperatures have been 25c+ outside whilst imaging.
It is too much drift if outside of H-a ! I have never experienced even +/-0,1A drift
from the position I have choosed for a given tuning. Quark(s) stays perfectly.
Guess they're all different!
rsfoto
Has thanked: 9723 times
Been thanked: 5773 times
Post by rsfoto »
Valery wrote: Mon Aug 13, 2018 3:58 pm Rainer,
According to Mark Wagner, who produce Solar Spectrum etalons (very much like DayStar does) the only correct ERF filter for such etalons is at least a red filter. The less unwanted heat from the sun will reach a etalon, the better etalon keeps it's position at a choosed wave length.
Hi Valery,
Yes that was my suspicion too. I already added a Fan and so far no problem to reach 6563.8Å. It increased the temperature fomr 6562.8Å to 6563.8Å in 3 minutes 30 seconds Looks like the heater is enough to get it to the required tempertaure. The Observatory at the moment is at about 22°C with closed roof.
Cooling down from 6563.8Å to 6562.8Å took 4 and 30 seconds.
I fouind some Peltier elements here in case that is not enough and maybe in future build a controlled cooler with an Arduino. :idea:
So, if I have some day Sun again :lol: , I can test how effective my cooler is. It is one tiny 40mm PC fan. If that is not enough I can add two more. At the moment there a thick dark grey clouds over the Observatory. :shock:
rsfoto
Post by rsfoto »
Here is my HIgh Tech cooling
rsfoto
Post by rsfoto »
I had some holes between thick clouds and fired up the scope. I think I am getting closer and closer. Sky was still not good. A lot of haze.
The imaging started with the Sun at an altitude of 55°. So I have to wait for better skies and then do a lot of imaging.
Takahashi TOA 130 at 4000mm focal length, Quantum 0.4Å and Lumenera Infinity 2-1RM with Lucam Recorder and false colour mask. 37 fps. Had to use Gain for good exposure to the right and therefore they got a bit noisy. This camera is very good with low noise using Gain compared to others.
Perhaps when I have the whole day clear sky I will put on the ASI 1600MM Pro again. Unfortunately the image streaming is not clean. I get a lot of hang ups. The least with FireCapture.
Now I just need to image image and image as much as possible in order to get experience. It is very hard to focus with the image moving like
:seesaw
pedro
Has thanked: 14 times
Been thanked: 6691 times
Post by pedro »
Just read this thread, nice setups. Please keep us posted
