Heya,
It was cloudy today, and seeing was poor, but there were moments of good seeing between clouds passing, so I stuck out and glad I did, as I got some decent data this morning. I worked the 6 inch refractor this time at two scales, with a 0.5x focal reducer and without as seeing allowed. Then switched to white light to do convection cells with the 6 inch using a near UV filter. It's a pretty void solar disc, but with a little more aperture there's always something to see, even in white light.
Equipment:
Scale 1: Celestron 152mm F8 Refractor + 210mm 2" Extension Tubes + Baader UV/IR Cut Filter (ERF) + Daystar Quark Chromosphere + GSO 0.5x Focal Reducer + ASI174MM Camera
Scale 2: Celestron 152mm F8 Refractor + 210mm 2" Extension Tubes + Baader UV/IR Cut Filter (ERF) + Daystar Quark Chromosphere + ASI174MM Camera
Scale 3: Celestron 152mm F8 Refractor + 115mm 2" Extension Tubes + Baader Blue CCD IR-Block Filter (ERF) + GSO 3x Barlow + 370~395nm Pass Filter + ASI174MM Camera
Colored Versions:
Scale 1:
Mosaic of AR & Filament
Scale 2:
Scale 3:
Today's Prominences, Active Region, Filaments, Convection Cells | Aug 12th 2018
- Has thanked: 1171 times
- Been thanked: 1360 times
- Has thanked: 20424 times
- Been thanked: 10242 times
Re: Today's Prominences, Active Region, Filaments, Convection Cells | Aug 12th 2018
A good looking set of images Marty
- Has thanked: 9401 times
- Been thanked: 5558 times
Hi Marty,
Well done
Well done
- Been thanked: 4904 times
Marty:
You had a super session.
- Has thanked: 17648 times
- Been thanked: 8787 times
The Sun looks like liquid gold, stunning images Marty
