another PST stage 2 mod
pedro
Has thanked: 14 times
Been thanked: 6685 times
Post by pedro »
Check out a few images of the 2 PSTs (H-alpha and CaK) and the parts for another PST Stage 2 mod
Imagepst_pst_CaK_20180813-07 by Pedro Ré, on Flickr
Imagepst_pst_CaK_20180813-01 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-19 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-17 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-14 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-10 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-07 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-02 by Pedro Ré, on Flickr
Imagepst_mod_stage2_20180813-05 by Pedro Ré, on Flickr
Imagepst_CaK_20180813-05 by Pedro Ré, on Flickr
Imagepst_20180813-10 by Pedro Ré, on Flickr
Has thanked: 20750 times
Been thanked: 10440 times
Re: another PST stage 2 mod
Nice!
pedro
Post by pedro »
Thanks Mark
pedro
Post by pedro »
Post by bart1805 »
Beautiful telescopes Pedro! Are you going to use the etalon in the f/7 beam? You could maybe try a Baader 1,7 Glasspath. Would give f/11,9.
pedro
Post by pedro »
I tried a 1.6X 2" barlow before the PST etalon but I still have to try other adapters
pedro
Post by pedro »
I also bought a Baader 1.25X Glasspath (it's on the way)
pedro
Post by pedro »
I'm still waiting for the Baader glasspath, I will keep you posted
Post by bart1805 »
The Glasspath works perfectly. Got the idea from banjo on this forum and use it myself in a 150mm f/8 Skywatcher. Mounted the Glasspath in the nosepiece.
pedro
Post by pedro »
Thanks Bart
Has thanked: 8523 times
Been thanked: 8253 times
Looking forward to seeing images from this mod, Pedro.
pedro
Post by pedro »
Thanks Stu
It works but it will be better after I install the Baader 1.25X glasspath, I will you keep you guys posted
pedro
Post by pedro »
I finally have all the pieces for my PST Satge 2 MOD. I received the Baader 1.25X Glasspath Corrector yesterday. I plan to use it maily with two telescopes> TMB100 F/8 and TEC140 F/7. Check out some images from my FLICKR page
ImagePST_STAGE_2_MOD_20180828-27 by Pedro Ré, on Flickr
BAADER 110mm ERF + Teflon Adapter + PST etalon and adapter
ImagePST_STAGE_2_MOD_20180828-13 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-12 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-10 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-07 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-05 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-03 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-17 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-19 by Pedro Ré, on Flickr
ImagePST_STAGE_2_MOD_20180828-21 by Pedro Ré, on Flickr
Post by bart1805 »
Nice! And now waiting for the first pictures. (-;
How did you mount the glasspath on the front lens? Ans I am curious if the distance between the back of the etalon and the focal point is about 20 cm, looks shorter. Or did you change the lens?
pedro
Post by pedro »
Thanks Bart
It's cloudy here but it will improve in a couple of days. I had to use a plastic spacer to fit the glasspath in front of the etalon. I cannot use a long distance after the PST etalon, otherwise I will not get my camera in focus. I will give it a go and let you know.
Post by bart1805 »
Interesting, I thought it was not possible so had it mounted in the nosepiece. But you still have the original front lens before the etalon?
Maybe the fact that you could not reach focus had something to do with the backfocus of the scope and the fact that you worked in a f/8 beam.
pedro
Post by pedro »
I did not try yet the mod with the Baader Glasspath in front of the etalon. I could reach focus without it
Where exactly did you mount the glasspath? Inside the nosepiece?
Mine is close to the etalon also inside the nosepiece
Post by bart1805 »
Hi Pedro,
Yes inside the nosepiece. I got the idea from banjo, in this thread there is also a drawing of his nosepiece. viewtopic.php?f=4&t=23610&p=212934&hili ... th#p212934
AOK made a nosepiece for me and mounted the glass path.
CS Bart.
pedro
Post by pedro »
Thanks for the link Bart
Mine is almost like that. It is not too close to the PST etalon
pedro
Post by pedro »
Tried the PST Stage 2 Mod today for the first time (TMB100 F/8). Visually it is great. For imaging it is not the same thing, big soft spot
Check out some images below.
More in a different thread
pedro
Post by pedro »
First light (TMB100 F/8 + PST Stage 2 Mod, X2 Barlow @X1.4)
more at: viewtopic.php?f=4&t=25032
pedro
Post by pedro »
PST STAGE 2 MOD | Pedro RÉ
TMB100 F/8, Baader 110mm ERF, PST etalon, Coronado BF15
http://re.apaaweb.com
pedro
Post by pedro »
PST STAGE 2 MOD | Pedro RE'
TEC140 F/7, Baader 165mm ERF, PST etalon, Coronado BF15
pedro
Post by pedro »
More images. Correct spacing (PST etalon, Baader 1.25X Glasspath). TMB100 F/7, Baader 110 ERF, PST Stage 2 Mod
Imagesolar_imaging_session_20180831-044 by Pedro Ré, on Flickr
Imagesolar_imaging_session_20180831-047 by Pedro Ré, on Flickr
Imagesolar_imaging_session_20180831-051 by Pedro Ré, on Flickr
Imagesolar_imaging_session_20180831-054 by Pedro Ré, on Flickr
Imagesolar_imaging_session_20180831-057 by Pedro Ré, on Flickr
Imagesolar_imaging_session_20180831-059 by Pedro Ré, on Flickr
Imagesolar_imaging_session_20180830-03 by Pedro Ré, on Flickr
pedro
Post by pedro »
A few more images
Two different PST etalons + Coronados BF15 & BF10 ----> back distance from the etalon - 14/15cm
Imagepst_stage2_mod_20180908-013 by Pedro Ré, on Flickr
Imagepst_stage2_mod_20180908-009 by Pedro Ré, on Flickr
Imagepst_stage2_mod_20180908-005 by Pedro Ré, on Flickr
Imagepst_stage2_mod_20180908-002 by Pedro Ré, on Flickr
Post by bart1805 »
And now it is a small step to doublestack the etalons. (-;
pedro
Post by pedro »
Hi Bart
I have a BIG soft spot with both etalons. Very different from my other H-alpha systems
pedro
Post by pedro »
PST Mod (PDF file)
http://astrosurf.com/re/PST_Stage_2_Mod ... 180911.pdf
Ré, P. (2018). PST Stage 2 Modification. Pdf file (2000kB)
more articles at:
http://re.apaaweb.com/pdfs_articles.html
Starry Jack
Has thanked: 141 times
Been thanked: 240 times
Post by Starry Jack »
Pedro,
In your excellent document (http://astrosurf.com/re/PST_Stage_2_Mod ... 180911.pdf), you mention the focus must come to a point 244mm from the rear of the rubber on the etalon. Where is that on your scope? The top of the diagonal? The middle of the eyepiece?
I've cobbled together a prototype yesterday using some pretty strange spare parts but it should work.
The other question is...I am using parts of a standard 2x barlow rather than the Glasspath. I've figured out the mounting in the prototype but does it need to be telecentric?
Jack
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
pedro
Post by pedro »
The measurement was made by Ken Harisson:
Ken Harrison (2005). Modifying a Coronado PST Hα Solar Telescope (PDF file).
The PST etalon must be correctly placed. Final focus should be 225 mm behind the rubber ring of the etalon.
You can use other parts, a X2 barlow should work fine. It needs to be telecentric
Starry Jack
Thanks, Pedro. I think my only confusion is where "final focus" is. I only use a video camera (no visual). Is that at the exit of the blocking filter? Or is it measured at the sensor chip? Or somewhere in between?
Best,
Jack
Aeries D-ERF
12nm Filter
pedro
Post by pedro »
Hi Jack
I tried several configurations and found out that a distance of 14cm from the rear of the PST etalon to the Coronado BF, works fine
ImagePST_stage_2_mod_20180830-032 by Pedro Ré, on Flickr
I did not reduce the OTA's length (did not cut the tube)
regards
Starry Jack
Got it. And I also found the document you referred to so I should be good to go. The biggest difficulty seems to be finding an ok n-stock telecentric lens.
Jack
Aeries D-ERF
12nm Filter
None of the lenses in this system are telecentric Jack - totally different thing!
OlegLviv
Has thanked: 911 times
Been thanked: 938 times
Post by OlegLviv »
I want returns to PST MOD2 because a few days ago arrived my TS 152/F5.9 and dont know how gets f10 for PST but have two ideas!
1.Buy Baader 1.7x Glasspath and will be have f10
2.I have Televue 2.0 Povermate 2x and can put front etalon but will be have F11.8
Which of the options will be the best????
Or maybe buy Lunt 50 with f7 and put Baader Glasspath 1.25?
What is the bandwidth of Pst and Lunt50? Pst 1A and Lunt 50 0,75A am right?
Thank you!
https://www.facebook.com/oleg.lavigne/
https://www.astrobin.com/users/RamonLviv/
https://www.astroclub.kiev.ua/forum/ind ... ic=46758.0
Telescope: TS 152/900/Bresser 102/1350
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Camera: Apollo Max 432M/ Apollo Mini 429M/Player One Mars II 462M/QHY 290MM
Mounh: 2xSky Watcher AZEQ6
Telecentric Lense: Televue Powermate 2/2.5x/4X/5X
pupak
Has thanked: 4376 times
Been thanked: 3974 times
Post by pupak »
AR150/F6 works well with TV5x PWMT and Quark which is similar to PST. You get F30 and the details are OK.
OlegLviv
Post by OlegLviv »
pupak wrote: Sun Nov 20, 2022 7:04 pm AR150/F6 works well with TV5x PWMT and Quark which is similar to PST. You get F30 and the details are OK.
I dont want quark because a few years sold him dont like this device.
If you know pst wants f10 without vingetting and Lunt 50 wants F7.
But now want better choice for my AR150/F6.
If you know had old model Lunt 60T with colimator f4 and its a bad choice for my AR150/F6 mod......
My friend can give me for test PST MOD2 with 2.0 Powernate2x =F11.8 or can buy Baader Glasspath 1.7 lens=F10 but PST etalon has only 1A and think that Lunt 50 with Baader Glasspath 1.7=F7.2 will be better with 0.75A than PST MOD2.
Which of the options will be the best with my TS 152/F5.9 ? (contrast and sweet spot)
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
