August 16 2018 AR12718 3 bands 280mm scope.
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hello to all,
Morning of the August 16 was calm and sunny - a good chance to image a new tiny AR12718 in CaK, UV 393nm and in H-a. My trusty C11 scope was equipped with the ARIES full size (295mm) DERF energy rejection filter and three narrow band filters - CaK (393nm, 2,2A FWHM), 393nm bandpass ( 20nm) filter and H-a 656nm (0,2A FWHM). Basler 1920-155 camera.
Seeing was OK.
Thanks for looking and comments.
PDB
Has thanked: 2 times
Been thanked: 149 times
Re: August 16 2018 AR12718 3 bands 280mm scope.
Post by PDB »
Valery,
you are usually producing quality images, but these are exceptional. Seeing was ok maybe is an understatement?
The glow in the CAK is great, granulation: can it be done better and that 0.2A H-Alfa, where did you find that filter ...
Has thanked: 1182 times
Been thanked: 1373 times
Post by MalVeauX »
Awesome resolution, seeing must have been killer!
LTHB
Been thanked: 581 times
Post by LTHB »
Hi Valery,
great pictures! The CaK in particular is terrific - I haven't seen any CaK image taken with amateur equipment that comes closer to the DOT images in terms of detail and resolution!
Would you tell us what exposure time you used and how many frames you stacked?
Frank
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Magnificent images, Valery!
Cheers, Peter.
Has thanked: 20757 times
Been thanked: 10444 times
Very good! I'm glad you got round to posting them.
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Well done, Valery.
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
Great images Valery
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Post by krakatoa1883 »
Wow, the K image is really impressive, great resolution indeed.
Has thanked: 17925 times
Been thanked: 8894 times
Goodness grief!!! unbelievable CaK, are you sure you aren't at one of the major solar observatories Valery :)
:bow :bow :bow
Post by Valery »
LTHB wrote: Sat Aug 18, 2018 9:27 pm Hi Valery,
Frank
Hi Frank,
Thanks for looking at these images.
Exposure time was 6ms and 1500 stacked images.
Been thanked: 4959 times
Post by eroel »
Valery:
The 2 first shots are superbly recorded and processed.
Post by Valery »
eroel wrote: Tue Aug 21, 2018 2:59 pm Valery:
Thanks, Eric
Can't understand whats wrong with the H-a image???
Post by eroel »
Valery:
Nothing wrong, the 3 images are stupendous, but as a personal taste I like the first 2 much more, for me the Ha is a bit oversharpened compared to the other two.
Post by Valery »
eroel wrote: Tue Aug 21, 2018 9:37 pm for me the Ha is a bit oversharpened compared to the other two.
Understand now. But I believe the image is not oversharpened - no noise (sand or dotty) and if I use a bit less of deconvolution, I start to loss the tiniest details which H-a image is full of. Not so with continuum image and in CaK core.
Have changed the H-a image for less sharpened one.
Has thanked: 8523 times
Been thanked: 8259 times
Exceptional images,Valery. Lots of wonderful details in all of them.
robert
Has thanked: 4 times
Been thanked: 1275 times
Post by robert »
Second one is really unusual. Very interesting result. All have great resolution. Thanks
Robert
Post by Valery »
Carbon60 wrote: Wed Aug 22, 2018 5:32 am Exceptional images,Valery. Lots of wonderful details in all of them.
Thanks, Stu
Note that the seeing was just OK, nothing special. May be a bit better when I recorded the CaK.
With Solar Scintillation Monotor such results should be achieveable in average climates. Especially if an aperture is smaller.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Valery...
These images are all very impressive...well done :bow
LTHB
Post by LTHB »
Hi Valery,
thanks (somewhat belatedly - I was very busy last week) for the info!
I am also shooting CaK at 6ms (or a little less) exposure time, but I mostly stack around 200 frames. I've never used a stack of more than 1000 frames, but I recall that Emil Kraaikamp says somewhere on his website, that he prefers to stack many pictures and, as he puts it, push the stack a bit harder.
So this is something to explore for me: Vary the stack size. I'll probably try this in both directions to see what works best: More than 1000 frames, as in your terrific image, but I'll also try much smaller stacks, as Christian recommends - if I can find a way to get less noisy videos, maybe with a different camera.
Thanks again and regards,
Frank
Post by Valery »
LTHB wrote: Sun Aug 26, 2018 2:07 pm
Frank,
The CaK image in this thread is far far not the best in resolution and details among all I have obtained during last year. I still hope to overcome my laziness and finally post my best CaK pictures.
LTHB
Post by LTHB »
I hope so, too! I, for one, would very much like to see them!
Frank
