August 16 2018 AR12718 3 bands 280mm scope.
Hello to all,
Morning of the August 16 was calm and sunny - a good chance to image a new tiny AR12718 in CaK, UV 393nm and in H-a. My trusty C11 scope was equipped with the ARIES full size (295mm) DERF energy rejection filter and three narrow band filters - CaK (393nm, 2,2A FWHM), 393nm bandpass ( 20nm) filter and H-a 656nm (0,2A FWHM). Basler 1920-155 camera.
Seeing was OK.
Thanks for looking and comments.
Seeing was OK.
- AR12718-2018-08-16-UT05h-46m-280mm-ARIES-DERF-PST-CaK-Basler-1920.jpg (488.33 KiB) Viewed 3107 times
- AR12718-2018-08-16-UT06h-04m-280mm-ARIES-DERF-393nm-Basler-1920.jpg (497.6 KiB) Viewed 3107 times
- AR12718-2018-08-16-UT06h-22m-280mm-ARIES-DERF-656nm-Basler-1920.jpg (494 KiB) Viewed 3107 times
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: August 16 2018 AR12718 3 bands 280mm scope.
Valery,
you are usually producing quality images, but these are exceptional. Seeing was ok maybe is an understatement?
The glow in the CAK is great, granulation: can it be done better and that 0.2A H-Alfa, where did you find that filter ...
- Has thanked: 1198 times
- Been thanked: 1390 times
Awesome resolution, seeing must have been killer!
Hi Valery,
great pictures! The CaK in particular is terrific - I haven't seen any CaK image taken with amateur equipment that comes closer to the DOT images in terms of detail and resolution!
Would you tell us what exposure time you used and how many frames you stacked?
Frank
Frank
- Has thanked: 20908 times
- Been thanked: 10564 times
Very good! I'm glad you got round to posting them.
- Has thanked: 9361 times
- Been thanked: 6193 times
- Been thanked: 6737 times
Great images Valery
- krakatoa1883
- Has thanked: 153 times
Wow, the K image is really impressive, great resolution indeed.
- Has thanked: 18050 times
- Been thanked: 8914 times
Goodness grief!!! unbelievable CaK, are you sure you aren't at one of the major solar observatories Valery
Hi Frank,LTHB wrote: ↑Sat Aug 18, 2018 9:27 pm Hi Valery,
Frank
Thanks for looking at these images.
Exposure time was 6ms and 1500 stacked images.
- Been thanked: 5005 times
Valery:
The 2 first shots are superbly recorded and processed.
Thanks, Eric
Can't understand whats wrong with the H-a image???
Valery:
Nothing wrong, the 3 images are stupendous, but as a personal taste I like the first 2 much more, for me the Ha is a bit oversharpened compared to the other two.
Understand now. But I believe the image is not oversharpened - no noise (sand or dotty) and if I use a bit less of deconvolution, I start to loss the tiniest details which H-a image is full of. Not so with continuum image and in CaK core.
Have changed the H-a image for less sharpened one.
- Has thanked: 8587 times
- Been thanked: 8322 times
Exceptional images,Valery. Lots of wonderful details in all of them.
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Second one is really unusual. Very interesting result. All have great resolution. Thanks
Robert
Robert
Thanks, Stu
Note that the seeing was just OK, nothing special. May be a bit better when I recorded the CaK.
With Solar Scintillation Monotor such results should be achieveable in average climates. Especially if an aperture is smaller.
- Has thanked: 65 times
- Been thanked: 4443 times
Hi Valery...
These images are all very impressive...well done
Hi Valery,
thanks (somewhat belatedly - I was very busy last week) for the info!
I am also shooting CaK at 6ms (or a little less) exposure time, but I mostly stack around 200 frames. I've never used a stack of more than 1000 frames, but I recall that Emil Kraaikamp says somewhere on his website, that he prefers to stack many pictures and, as he puts it, push the stack a bit harder.
So this is something to explore for me: Vary the stack size. I'll probably try this in both directions to see what works best: More than 1000 frames, as in your terrific image, but I'll also try much smaller stacks, as Christian recommends - if I can find a way to get less noisy videos, maybe with a different camera.
Thanks again and regards,
Frank
Frank
Frank,LTHB wrote: ↑Sun Aug 26, 2018 2:07 pm
The CaK image in this thread is far far not the best in resolution and details among all I have obtained during last year. I still hope to overcome my laziness and finally post my best CaK pictures.
I hope so, too! I, for one, would very much like to see them!
Frank
Frank
