Sunspot 2719 in 3 wavelengths, Convection Cells, Proms | Aug 20th
MalVeauX
Has thanked: 1179 times
Been thanked: 1369 times
Post by MalVeauX »
Heya,
Woke up to another sky with some potential, the clouds were around, but not bad, the seeing was dreadful at first. Then it just snapped into good seeing for a brief amount of time (around 0930am, then clouds rolled in by 1000am), so I quickly grabbed data on the newly designated AR2719 in various wavelengths of interest to compare, in white light (370~395nm, near UV to see convection cells better) of the photosphere, 393nm to see the faculae better and the merging of the photosphere and chromosphere (note the convection cells are in and out, bandpass is not tight enough, but getting close), and 656nm to see the chromosphere of course. Imaged with a Celestron 152mm F8 refractor and a Quark for the HA. Used a 3x barlow and a 370~395nm pass filter for the UV white light. Used a 3x barlow and a Skybender loaded with 393nm filters for the CA. Camera was ASI174MM.
rsfoto
Has thanked: 9677 times
Been thanked: 5754 times
Re: Sunspot 2719 in 3 wavelengths, Convection Cells, Proms | Aug 20th
Post by rsfoto »
WOW WOW WOW
Hi Marty,
Spectacular images.
regards
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Post by krakatoa1883 »
Superb images.
Are you fine with the black tube of the 150 ? I have a Celestron refractor too and although the tube remains in shadow when pointed to the Sun, I noted an improvement in seeing conditions since I made the tube white, now it is colder than before.
Raf
MalVeauX
Post by MalVeauX »
rsfoto wrote: Mon Aug 20, 2018 7:06 pm WOW WOW WOW
Hi Marty,
Spectacular images.
A question. That tilter is custom made or who sells them ? Thanks
regards
Hi Rainer,
The tilt chamber is a skybender, they're no longer for sale (never really were for sale), but they move around the community. There's a thread about them in the modification forum here on solarchat. The only thing to it is having a mechanism that can tilt a filter to tune it, but with very good precision. I don't use it that much as I don't have filters that are narrowband enough at this time, but it's my only way to get even close to calcium, so that is what I use it for.
I wonder if an interference or tilt adapter could be fashioned to do the same thing? Extreme angles are not needed after all... hrm.
More info here:
viewtopic.php?f=9&t=24440
MalVeauX
Post by MalVeauX »
krakatoa1883 wrote: Mon Aug 20, 2018 7:16 pm Superb images.
Hello,
I'm currently ok with the black tube. However, as you noted, it gets hotter in general, than a white tube would, theoretically. I am considering painting it white, or at least wrapping it with reflective insulation, or maybe wrapping it with a kind of white tape even. I've never painted a tube, so maybe I will wrap it first instead.
Alternatively, simply replacing the lens hood and putting a shield around the hood to block all light from touching the tube may have the same cooling effect. Being realistic, if the tube isn't being touched by direct light, it shouldn't have a temperature difference between colors as long as they're not directly in contact with the sunlight or significant reflected light. A big collar, perhaps, might do the trick. The lens hood is black, and it is removeable. Maybe I will start by painting that white and making a color that is reflective.
I'll try a few things and do some temperature tests and post results when I can.
Thanks!
rsfoto
Post by rsfoto »
MalVeauX wrote: Mon Aug 20, 2018 7:21 pm
Hi Marty,
Spectacular images.
regards
Hi Rainer,
More info here:
Hi Marty and Thanks.
I am on the drawing board :-)
regards
Has thanked: 17894 times
Been thanked: 8887 times
Wow!! these are magnificent images :bow :hamster:
