HR G band images taken on Aug 19 with the Newton 300mm
- Been thanked: 2713 times
Dear All,
Here are some first images taken at the site of St Véran observatory (2930 m) with the 300 mm solar telescope. I use a 430 nm FWHM 1.9 nm filter.
A small pore with another small one on the left side of the image. Many filigrees are visible in the intergranular region :
A new very small group on the East limb :
Best regards
Christian
Best regards
Christian
- Been thanked: 4340 times
Re: HR G band images taken on Aug 19 with the Newton 300mm
Christian...
These are exceptional images...well done
- Has thanked: 1171 times
- Been thanked: 1360 times
Awesome Christian! Love that G-band!
What do you think is the minimum aperture needed (assuming good seeing) to see the FE atoms in G band?
Thanks !
Marty, my guess is that a 250 mm aperture is the minimum. But it would be worth to try it with a 200 mm aperture.
- Has thanked: 9145 times
- Been thanked: 6025 times
- Has thanked: 8418 times
- Been thanked: 8164 times
It's a beautiful place from which to image the Sun, Christian. Fabulous hi-res images. Lots of fine G-band detail.
- Been thanked: 8792 times
Absolutely superb
Can you give some more information about the site? do you stay there, drive the car there, walk the telescope up there? what power supplies do you have?
Thanks Stu and Franco :-)
Alexandra, here is the website of Astroqueyras :
https://www.astroqueyras.com/
It is easier to get up there with a 4-wheel drive.
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Outstandin HR images Christian, fantastic resolution
Pedro Re'
