Flying over the sun eastern limb in a 280mm scope.
Post by Valery » Sun Sep 23, 2018 6:31 pm
Hi to all,
Once flew over the spotless sun eastern limb with a 280mm SCT (very poor at 393nm?) .
Bands were H-a DS, Ca-II-K 2.2A, 393nm 10nm
Seeing was average with some improvements to a good one.
Hope you like these photos taken during that flight.
PS. Flight #2 was near the center of the spotless sun and was successfull too. But this is another story. Will tell you later.
Right click on the images, open them in a separate window to see them at a full resolution.
Blue wing of Ca-K 2,2A
393nm continuum
H-a DS
Re: Flying over the sun eastern limb in a 280mm scope.
Post by marktownley » Sun Sep 23, 2018 7:40 pm
Very impressive as always Valery! No safix with the c11 then?
eroel
Post by eroel » Mon Sep 24, 2018 12:12 am
Valery:
Super shots.
Post by Valery » Mon Sep 24, 2018 6:59 am
TheSkyBurner wrote:
Sun Sep 23, 2018 11:18 pm
The halpha is clearly much better defined than the 393.4. If you look at the top portion of your calcium image it is fairly blurred(this could simply ge from the low intensity transmission of the pst filter) Not complaing, its far greater than what ill be imaging and pretty much anyone else on the forum in the next 10 years.
But you can certainly do better!
Apples and oranges....
1. I certanly will do better, at least due to a greater aperture - the C14.
2. My goal is: all ARIES 2/3 bands filters owners should do at least comparable images, better if they will surpass my results.
3. This CaK image suffer from insufficient S/N due a rust on the blocking filter. Need to change the blocking filter.
Second reason is that at the edge the CaK "relief" is MUCH worser defined vs H-a DS. Regardless of filtration. This is nature of these supergranulation cells.
And, this is not my best CaK image. Far not the best.
Thanks for your critical note. Will work more about aestetical level of published CaK images.
Post by Montana » Mon Sep 24, 2018 9:13 am
These are thoroughly beautiful Valery, I prefer you to put all images up, not just the very best, it gives us something to aim for :)
Congratulations on a very well deserved SPOD :hamster:
:bow
Post by marktownley » Mon Sep 24, 2018 6:52 pm
What filters are you using in the CaK module Valery?
Derek Klepp
Post by Derek Klepp » Tue Sep 25, 2018 7:44 am
Valery great SPOD
Post by Valery » Wed Sep 26, 2018 12:41 pm
I do use Edmund 10nm 393nm, PST CaK #2 + PST CaK #1. I need to replace the PST CaK #2 with a second Edmund 10nm 393nm. Or just buy a Baader K-line filter and use it with #1 PST CaK.
robert
Post by robert » Wed Sep 26, 2018 5:06 pm
Great shots anyway!
Post by Carbon60 » Thu Sep 27, 2018 5:41 am
Excellent images, Valery. You continue to set the bar very high. Thanks for showing us what CAN be done.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Users browsing this forum: No registered users and 11 guests
