High resolution images taken on Aug 20, 21&23th with the 300 mm solar telescope
- Has thanked: 1 time
- Been thanked: 2725 times
Dear all,
Here is another set of images taken on August with the 300 mm from St Véran observing site at 2930 m altitude.
Granulation on August, 20 at 430 nm :
Granulation on August, 21 at 430 nm :
Granulation on August, 21 at 396 nm in another place. Note the many filigrees:
AR2719 on August, 20 at 430 nm with faculae :
AR2719 on August, 21 at 430 nm :
AR2719 on August, 23 at 430 nm. The field is crowded with filigrees. Note the deformed granulation next to the pores on lower left and the uncompleted filaments around the largest pore at the centre:
Best regards
Best regards
- Has thanked: 9387 times
- Been thanked: 6199 times
Re: High resolution images taken on Aug 20, 21&23th with the 300 mm solar telescope
Truly excellent results, Christian
- Has thanked: 65 times
- Been thanked: 4459 times
Superb results form these sessions Christian...incredible resolution
- Has thanked: 8588 times
- Been thanked: 8324 times
OMG, Christian. Absolutely fabulous images. A beautiful demonstration of the importance of aperture and seeing for high end imaging.
- Has thanked: 18105 times
- Been thanked: 8941 times
Truly remarkable these are certainly best appreciated when opened in a new tab and seen at full size.
Thanks Christian really enjoyed these.
- DSobserver
- Been thanked: 19 times
- Been thanked: 5016 times
Christian:
Superb resolution.
Superb resolution.
- Has thanked: 20940 times
- Been thanked: 10587 times
Brilliant Hi Res Christian!
Thanks a lot :-)
You've aced it at 300mm Christian, we expect more aperture the next time you are high in the mountains
Thanks Mark,
St Véran site is certainly worth a 400 mm solar telescope, but that would be too large / heavy for me.
