Boring Sun
krakatoa1883
Boring Sun
Post by krakatoa1883 » Fri Sep 28, 2018 7:03 pm
I prepared all my solar toys this morning only to discover later that there were really few details to image. I started with some granulation in K line but I soon give up as eventually I didn't see any sense in this, particularly after Christian showed us his results :lol:
So, only a full disc, some small prominences on the SE limb (but not in detail because I noticed them only too late while processing the disc image) and a portion of the SE limb, all with the calcium Quark to which I replaced the IR-eater glass with an Astronomik IR-cut noting an improvement in sharpness. Of the original BF I left in place only the blue glass.
Raf
My personal page on Google+
Re: Boring Sun
Post by Carbon60 » Fri Sep 28, 2018 7:39 pm
So incredibly quiet. Nice images, though, Raf.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
krakatoa1883
Re: Boring Sun
Post by krakatoa1883 » Fri Sep 28, 2018 8:36 pm
Thanks Stu. Today's page of Spaceweather.com has an
interesting article on some consequences of this solar minimum, it's worth a reading.
Apollo, yes calcium Quark is heat tunable however the bandpass is large (5A) therefore tuning has only a limited effect. Tried to stack it with a Omega Optical CaH filter but images are too dark.
Raf
Re: Boring Sun
Post by ffellah » Sat Sep 29, 2018 12:21 am
Still very nice images, Raf...
Re: Boring Sun
Post by marktownley » Sat Sep 29, 2018 8:23 am
Looking good there Raf!
krakatoa1883
Re: Boring Sun
Post by krakatoa1883 » Sat Sep 29, 2018 12:01 pm
Thanks! Look at today's hedge on the SE limb if you can.
EDIT: I mean this one
Raf
Re: Boring Sun
Post by ffellah » Sat Sep 29, 2018 1:44 pm
Raf: congratulations on the SPOD !
Franco :band
krakatoa1883
Re: Boring Sun
Post by krakatoa1883 » Sat Sep 29, 2018 2:41 pm
Thank Franco, very kind :)
Raf
Re: Boring Sun
Post by marktownley » Sat Sep 29, 2018 3:43 pm
Got a pic of the quark with its new filter Raf?
krakatoa1883
Re: Boring Sun
Post by krakatoa1883 » Sat Sep 29, 2018 7:21 pm
This is the original BF composed by a blue thick glass and a clear thin one, I suppose a KG3 or something like that
they were glued but after about one year the glue became degraded and fissured although I have always been careful not to use the device with apertures greater than 80mm without an additional UV/IR cut filter.
I cleaned all surfaces, put back the blue glass in the Quark and screwed the clear glass on the Quark's nose as (luckily) the glass has the same diameter of the most common eyepiece filter (I simply used a 1.25" spare ring)
Later I replaced the clear glass with the Astronomik IR cut, now my Quark appears this way
Raf
Re: Boring Sun
Post by marktownley » Sun Sep 30, 2018 11:39 am
Thanks Raf
Re: Boring Sun
Post by Montana » Mon Oct 01, 2018 10:09 am
Never let anyone else's pictures put you off taking your own :) it is the pleasure of seeing the Sun and seeing anything on it whether it be small or large that is the delight :)
These are super images :bow
Users browsing this forum: No registered users and 8 guests
