Whirling Prom Animation 20181007
Christopher
Post by Christopher » Tue Oct 09, 2018 10:22 pm
This is my first attempt at a Halpha animation. Data capture was Sunday (10/7) between 1:17 and 2:02PM EDT. I did 10 seconds every minute for 45 minutes and ended up with 23 usable frames as seeing was pretty lousy. Here's the gear list for this capture:
Zeiss APQ130/Solar Spectrum Mod T-Scanner 0.6A FWHM/Baader TZ4/Astro-physics ERF/Astro-physics Mach1/PGR Grasshopper 3
Constructive criticism highly welcomed!!
Chris
Christopher
Zeiss APQ 130, MiniBorg 45ED, Lunt 100THa
Has thanked: 55 times
Been thanked: 34 times
Re: Whirling Prom Animation 20181007
Post by ffellah » Wed Oct 10, 2018 12:04 am
Very nicely done, Christopher !
Christopher
Post by Christopher » Wed Oct 10, 2018 2:15 am
Hi Skyburner,
Yes! That’s amazing. I absolutely had a vision of whirling dervishes when I first saw the 45 frames in sequence and your rendition nails it. Thank so much! I used FireCapture, Autostakkert, IMPPG (sharpening), Photoshop (align and animate). I’m sure with time one develops patience but boy I’ll tell you, the first time around I just knew I had something and wanted to see it move :lol: I can see that I way undersharpened. And level adjust totally makes sense. From what you’re saying I gather I could load the 45 final frames in RegiStax and avoid having to manually align them in PS. Is that correct?
Thanks to you Franco!
Christopher
robert
Has thanked: 1 time
Been thanked: 18 times
Post by robert » Wed Oct 10, 2018 12:16 pm
Lovely animation and great additions. I would add that ImPPG is very good for aligning frames too, anyhow all very interesting
Robert
menu item
imppg menu.jpg (56.99 KiB) Viewed 950 times
screen to use for aligning
imppg align.jpg (174.97 KiB) Viewed 950 times
2020 images https://tinyurl.com/v6muwvm
Christopher
Post by Christopher » Thu Oct 11, 2018 2:37 am
Terrific. Many new things to try. I really appreciate all the feedback.
Christopher
Has thanked: 864 times
Been thanked: 344 times
Post by marktownley » Thu Oct 11, 2018 6:33 am
Lovely results Christopher!
Christopher
Post by Christopher » Mon Oct 15, 2018 12:47 am
Based on lots of great feedback here I've learned some new techniques and reprocessed this animation. I must say, the event takes on a bit of a different character. Rather than whirling proms, one sees quite clearly the massive double magnetic pulse unleashed through this prom group. Each of those pulses lasts just under 5 minutes in real time and they' occur about 20 minutes apart (the more powerful burst is first in sequence). Makes me wonder what I missed as I got clouded out at the end and still had some SSD space left :roll: This is all 44 frames (good and bad).
Christopher
