Today's SUN (20181013) | imaged through high clouds
- Been thanked: 6577 times
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2018-10.html
IMAGING SETUPS
IMAGING SETUPS (Sky-Watcher SolarQuest Mount)
Another observing session with the SolarQuest mount and cloudy skies. After first alignment (Heliofind) it helps to cover the solar sensor. Tracking was great for about 3h
SUN (20181013) H-alpha DISK & PROMS (12:30 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
SUN (20181013) CaK PROMS (12:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20181013) WL, CaK & H-alpha (12:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPE 3 GS3-U3-28S4M
WEBLINK:
IMAGING SETUPS
- Has thanked: 20435 times
- Been thanked: 10245 times
Re: Today's SUN (20181013) | imaged through high clouds
Good captures there Pedro!
- Been thanked: 4904 times
Pedro:
Nice session and nice information of the Solar Quest mount.
Abrazo,
Abrazo,
Thanks Mark & Eric
I'm loving the SolarQuest. It works like a charm even with cloudy skies
- Has thanked: 1171 times
- Been thanked: 1360 times
Nice Pedro! Looks like a nice little portable setup too, looks great!
Thanks Marty
You can find a review here:
Ré, P. (2018). Sky-Watcher SolarQuest Mount. PDF File
http://www.astrosurf.com/re/solarquest_ ... 181008.pdf
more at:
viewtopic.php?f=27&t=25170
more at:
- Has thanked: 9144 times
- Been thanked: 6025 times
Are you going to be affected by Leslie where you are Pedro?
Yes Mark
It is approaching Portugal as we speak. Winds of 150Km/h are expected in coastal areas
huricane_leslie_20181013 by Pedro Ré, on Flickr
- leslie.jpg (663.36 KiB) Viewed 2706 times
Stay safe Pedro!
- Been thanked: 4340 times
Great FD images Pedro
Hope the approaching storm doesn't affect you too badly.
- Been thanked: 171 times
Thanks Pedro I was wondering about those mounts.I have not been very active in Solar of late but did manage a bit of a break on a recent outback trip.
Thanks guys
Everything is OK, the hurricane was the biggest since 1842. Rain and strong winds during the night
Derek: SolarQuest is a great little mount for outreach and solar observation, it works like a charm
What kind of dovetail do you use to handle the PST to solarquest sadlle?
Can handle the PST to solarquest sadlle with Versatile L-shaped dovetail bracket by rotating the sadlle to 90 degree?
Aleixo
Aleixo
I used a normal dovetail. Since the PST has a fixed eyepiece you can use the L-shaped dovetail.
Caro
Pedro Ré
Esta dovetail serve para o PST acoplar à solar quest? É a pergunta que me fez o Raimundo
https://www.astroshop.eu/mounting-plate ... r_1_select
Grato pela atenção
Aleixo
Pedro Ré
Grato pela atenção
Aleixo
Sim mas não é a dovetail em forma de L que é mais adequada para usar com a SolarQuest
Este é o modelo que eu uso
