Woke up to a cloudy sky but had some sucker holes. The AR's are pretty large, so I had to attempt some mosaics to be able to frame them up. I did two at different times, and you can see the differences in AR2725, it's a feisty little AR and has some activity going on spitting some filaments around in a short period of time. Some large proms are still on the limb, but I had a hard time with them through the clouds which really robbed the transparency and killed the exposure, but they're still represented.
Celestron 150mm F8 Refractor + Daystar 150mm ERF + Baader 50mm UV/IR Block Filter + Quark + ASI174MM
Coronado PST + 1.5x Barlow + ASI174MM
B&W's:
Colored:
Setup:
AR2724 & AR2725 High Res Mosaic, Proms, FullDisc | 150mm, 40mm, HA | Oct 18th 2018
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Re: AR2724 & AR2725 High Res Mosaic, Proms, FullDisc | 150mm, 40mm, HA | Oct 18th 2018
A really nice set of images and productive run there Marty!
- krakatoa1883
- Has thanked: 153 times
Very detailed views, Marty, great images.
Be careful that not all Quarks perform as Marty's one, better to have the possibility to select one among several units.TheSkyBurner wrote: ↑Fri Oct 19, 2018 1:40 amYour images really make me want to get a quark. That thing operates way better than my three pst mod's and 4 lunt scopes i have owned.
Hi great shots as usual Marty, I really like the full disks and the proms, fantastic detail.
- Been thanked: 4427 times
Great session Marty
Thank you all,
