AR12724/25 remnants at high res 280mm C11
Hi all,
Here are two photos of AR 2724 and 2725 remnants. No spots in them now. However they looks fine in a C11 280mm telescope.
I used two etalons. 1. Quark Chromosphere with FWHM close to 0,2A and the second one is my best hand selected PST etalon worked in a telecentric scheme. Quark worked at F/43 and the PST worked at F/D>50 both with a followed focal reducer at around 0,65x.
You can see that a proper telecentric system works fine with a good airspaced etalon. I personally can't see any significant
diffeernce between these two systems, while a theory tells us that an airspaced etalon works in a telecentric configuration
far not as good as a solid spaced etalon. We can see that this is not always the case. Some very narrow air spaced etalons keep
their own quite good in a slow telecentric scheme.
Thanks for looking.
Thanks for looking.
- Oct-19-2018-UT7h-21m-C11-ARIES-295mm-DERF-PST.jpg (486.93 KiB) Viewed 2111 times
- Oct-19-2018-UT8h-12m-C11-ARIES-295mm-DERF-QUARK.jpg (494.35 KiB) Viewed 2111 times
- Has thanked: 1188 times
- Been thanked: 1382 times
Re: AR12724/25 remnants at high res 280mm C11
Thanks, Marty. You may be not believe, but this given post at least for 50% was targetted for you. This is where you can be with your 10" Meade or better with a C11, which are very cheap and powerfull enough and are better solutions for lunar and planetary lucky imaging than what you can do with a 6" refractor or an 8" SCT even if it HD version. There is no substitution for an aperture.
I'm saving towards it. I think my 10" is not worth using for this, it's just too old of a scope (30+ years old). And to get another big scope and use smaller scopes with it, I'd have to get a new mount and everything too. I'm using the 6" refractor right now just because I have it, and the ERF I'm using is a loaner. Saving towards an 8" ERF. While I'd love to have a bigger scope and bigger ERF, I have to be realistic with budget since I really want a three scope setup that is permanent in my observatory (big aperture scope, small achromat for white light, CaK full disc and a double stacked smaller HA scope). I'll probably end up with a C8 Edge. Soon!Valery wrote: ↑Sun Oct 21, 2018 12:01 amThanks, Marty. You may be not believe, but this given post at least for 50% was targetted for you. This is where you can be with your 10" Meade or better with a C11, which are very cheap and powerfull enough and are better olutions for lunar and planetary lucky imaging than what you can do with a 6" refractor or an 8" SCT even if it HD version. There is no substitution for an aperture.
My C11 is very old and of average optical quality. With a powerful deconvolution software we all use, a telescope can be of very middle quality.
How is the transmission when you double stack the PST etalon & the Quark together? Do you prefer single stack for surface imaging like this?
- Has thanked: 20783 times
- Been thanked: 10476 times
Great close ups Valery and good demonstration of what is possible. I wish my seeing conditions supported such aperture.
- Been thanked: 4425 times
Hi Valery...
These show an amazing amount of detail with the narrow band-pass and large aperture. Excellent work
The transmission in such a combination is mostly defined by transmission in:
1. Blocking filter - can be vary up to 2x !
2. Quark and PST etalon transmission. Can vary up to 3x!
So, a telescope is the last and the least factor in transmission.
When image active areas, especially with large spots and spiculaes and prominences at the limb I prefer a narrow single stacked etalon like my best Quark and my best PST etalon.
For imaging of "desert" areas, dark filaments, prominences near limb, some smaller spots I prefer a double stacked combination.
- Been thanked: 8906 times
- Has thanked: 8556 times
- Been thanked: 8285 times
Super images, as usual, Valery.
Stu
Stu
