RAW stacked image in CaK with 280mm SCT
Post by Valery » Sun Oct 21, 2018 1:19 am
Hi all,
If any of you are interested in trying your processing skill.
This is a RAW stacked image in CaK taken May 31 2018 with my C11 equipped with ARIES 296mm DERF.
Filter - PST CaK #1 + original PST BF filter #2 + Edmund 10nm 393nm
Camera Basler 1920-155
800 frames stacked
Have fun.
_SUN_080924_AS_f800_g4_ap3973 bw.png (3.99 MiB) Viewed 1027 times
DJD
Re: RAW stacked image in CaK with 280mm SCT
Post by DJD » Sun Oct 21, 2018 6:44 am
Valery,
Thanks for posting raw image. I love processing other folks images trying to reproduce their results using my
usual methods.
In this case it was more interesting as I haven't processed any CaK images before. I had quite a lot of trouble deciding what was
noise and what was artefact from my heavy touch tools. So here is a first pass.
David
Post by Valery » Sun Oct 21, 2018 12:48 pm
TheSkyBurner wrote:
Sun Oct 21, 2018 7:59 am
I choose fire, because winter is coming!
This is good palette for a Ca-II I at infrared 854,21nm !
Post by Valery » Sun Oct 21, 2018 12:49 pm
Valery,
usual methods.
David
Very nice first CaK processing, David!
Post by Montana » Mon Oct 22, 2018 11:14 am
Thanks Valery, I will have a go at this at home. Is this using a Saffix as well?
Post by Valery » Mon Oct 22, 2018 12:55 pm
No SAFIX, Alexandra! With ARIES filter you will have such a sharpness from your 11" SCT. Just hunt for the seeing! SSM will greatly help in this.
BTW. Have you received the DERF yet?
Post by Valery » Mon Oct 22, 2018 12:57 pm
BTW A year or so back such an offer of a RAW image for post processing will be quite demanding. But not now. Does the solar minimum is so damaging?
May be you, folks, need less boring image(s) for postprocessing?
Post by Montana » Mon Oct 22, 2018 1:58 pm
Valery, yes the DERF is at the hubby's work in the safe (he told me today). When we get it home tonight it will be the big reveal :)
Would the Lunt CaK module work?
MalVeauX
Post by MalVeauX » Mon Oct 22, 2018 2:57 pm
I took a quick look at it with some color.
Post by Montana » Mon Oct 22, 2018 6:03 pm
All safe and well and very well packed :) :hamster:
p_zetner
Post by p_zetner » Mon Oct 22, 2018 7:44 pm
Hi Valery.
Here's my version.
Peter
SUN_080924_AS_f800_g4_ap3973 bw_proc2.png (3.35 MiB) Viewed 879 times
Workflow details:
ImagesPlusv5.5:
2.0X scale change.
Adaptive Lucy-Richardson deconvolution (200 iterations, 11x11 px)
Multi-resolution sharpening.
0.5X scale change.
Photoshop CS4:
HDR Efex Pro2: Tone mapping filter #5 - normal blend 60% opacity
HDR Efex Pro2: Tone mapping filter #4 - overlay blend 30% opacity
Curves adj (mild)
Smart sharp (1.5px 75%) - normal blend 40% opacity
Local Curves adj (mild ) in sunspots.
Curves adj (mild)
Despeckle - 50% opacity
Post by Valery » Mon Oct 22, 2018 11:32 pm
1. Nice to know that the DERF came intact to you! It get a good home! I hope that Stu will help you will the cell.
2. Yes, the Lunt CaK diagonal or straight will work just fine. Tell me what is the camera you plan to use with this
telescope. I need to know the pixel size.
Post by Valery » Tue Oct 23, 2018 12:28 am
This is make take #1
_SUN_080924_AS_f800_g4_ap3973 bw proc.png (1.36 MiB) Viewed 865 times
Post by Montana » Tue Oct 23, 2018 1:46 pm
Hello Valery
I have a Grasshopper 3 GS3-U3-28S5M-C and a Lunt CaK diagonal, is there any hope?
PS Cracking image Valery!
p_zetner
Post by p_zetner » Tue Oct 23, 2018 2:10 pm
Love the deep contrast in your processing, Valery.
My attempt to come close is below.
Are you using some kind of line or edge enhancement filter?
Peter
SUN_080924_AS_f800_g4_ap3973 bw_lin-enhanc_proc0.png (3.36 MiB) Viewed 796 times
Post by Valery » Tue Oct 23, 2018 3:32 pm
No, I don't use such a software.
Post by Valery » Tue Oct 23, 2018 4:55 pm
I would say that this camera is not fast enough for imaging with such a large aperture telescope.
In my opinion there are two cameras which can be used with good chances for a success.
ZWO ASI190MM and Basler 1920-155. They are fast enough.
I now extensively test these both cameras side by side. For CaK I prefer 290MM. For Ha I need more
tests to be done.
150fps or faster is out choice.
ASI290MM is much cheaper and should be the best choice.
Post by marktownley » Tue Oct 23, 2018 7:13 pm
Can you describe the processing you do Valery please?
Post by Valery » Thu Oct 25, 2018 2:10 pm
Hi Mark,
All my efforts to formalize the work flow to a single stable sequence have failed. All depends of how good the initial recorded movie is, how noised it. All I can say is that I do use two instruments: Astra Image Pro 3.0 and Photoshop CS6. In AI I mostly use Maximum Entropy and LR deconvolutions. And a lot of intuitive steps - depends how the processing is going. Net season I will finally go with SSM - in hope to get better quality of recorded movies.
Users browsing this forum: Bing [Bot], marktownley and 12 guests
