RAW stacked image in CaK with 280mm SCT
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
If any of you are interested in trying your processing skill.
This is a RAW stacked image in CaK taken May 31 2018 with my C11 equipped with ARIES 296mm DERF.
Filter - PST CaK #1 + original PST BF filter #2 + Edmund 10nm 393nm
Camera Basler 1920-155
800 frames stacked
Have fun.
_SUN_080924_AS_f800_g4_ap3973 bw.png (3.99 MiB) Viewed 3368 times
DJD
Has thanked: 42 times
Been thanked: 133 times
Re: RAW stacked image in CaK with 280mm SCT
Post by DJD »
Valery,
Thanks for posting raw image. I love processing other folks images trying to reproduce their results using my
usual methods.
In this case it was more interesting as I haven't processed any CaK images before. I had quite a lot of trouble deciding what was
noise and what was artefact from my heavy touch tools. So here is a first pass.
David
Post by Valery »
TheSkyBurner wrote: Sun Oct 21, 2018 7:59 am I choose fire, because winter is coming!
This is good palette for a Ca-II I at infrared 854,21nm !
Post by Valery »
DJD wrote: Sun Oct 21, 2018 6:44 am Valery,
usual methods.
David
Very nice first CaK processing, David!
Has thanked: 17925 times
Been thanked: 8894 times
Thanks Valery, I will have a go at this at home. Is this using a Saffix as well?
Post by Valery »
Montana wrote: Mon Oct 22, 2018 11:14 am Thanks Valery, I will have a go at this at home. Is this using a Saffix as well?
No SAFIX, Alexandra! With ARIES filter you will have such a sharpness from your 11" SCT. Just hunt for the seeing! SSM will greatly help in this.
BTW. Have you received the DERF yet?
Post by Valery »
BTW A year or so back such an offer of a RAW image for post processing will be quite demanding. But not now. Does the solar minimum is so damaging?
May be you, folks, need less boring image(s) for postprocessing?
Valery, yes the DERF is at the hubby's work in the safe (he told me today). When we get it home tonight it will be the big reveal :)
Would the Lunt CaK module work?
Has thanked: 1180 times
Been thanked: 1371 times
Post by MalVeauX »
I took a quick look at it with some color.
All safe and well and very well packed :) :hamster:
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Hi Valery.
Here's my version.
Peter
SUN_080924_AS_f800_g4_ap3973 bw_proc2.png (3.35 MiB) Viewed 3220 times
Workflow details:
ImagesPlusv5.5:
2.0X scale change.
Adaptive Lucy-Richardson deconvolution (200 iterations, 11x11 px)
Multi-resolution sharpening.
0.5X scale change.
Photoshop CS4:
HDR Efex Pro2: Tone mapping filter #5 - normal blend 60% opacity
HDR Efex Pro2: Tone mapping filter #4 - overlay blend 30% opacity
Curves adj (mild)
Smart sharp (1.5px 75%) - normal blend 40% opacity
Local Curves adj (mild ) in sunspots.
Curves adj (mild)
Despeckle - 50% opacity
Post by Valery »
Montana wrote: Mon Oct 22, 2018 1:58 pm
1. Nice to know that the DERF came intact to you! It got a good home! I hope that Stu will help you with the cell.
2. Yes, the Lunt CaK diagonal or straight will work just fine. Tell me what is the camera you plan to use with this
telescope. I need to know the pixel size.
Post by Valery »
This is my take #1
_SUN_080924_AS_f800_g4_ap3973 bw proc.png (1.36 MiB) Viewed 3206 times
Hello Valery
I have a Grasshopper 3 GS3-U3-28S5M-C and a Lunt CaK diagonal, is there any hope?
PS Cracking image Valery!
p_zetner
Post by p_zetner »
Love the deep contrast in your processing, Valery.
My attempt to come close is below.
Are you using some kind of line or edge enhancement filter?
Peter
SUN_080924_AS_f800_g4_ap3973 bw_lin-enhanc_proc0.png (3.36 MiB) Viewed 3137 times
Post by Valery »
p_zetner wrote: Tue Oct 23, 2018 2:10 pm
No, I don't use such a software.
Post by Valery »
Montana wrote: Tue Oct 23, 2018 1:46 pm
I would say that this camera is not fast enough for imaging with such a large aperture telescope.
In my opinion there are two cameras which can be used with good chances for a success.
ZWO ASI190MM and Basler 1920-155. They are fast enough.
I now extensively test these both cameras side by side. For CaK I prefer 290MM. For Ha I need more
tests to be done.
150fps or faster is our choice.
ASI290MM is much cheaper and should be the best choice.
Has thanked: 20756 times
Been thanked: 10442 times
Valery wrote: Tue Oct 23, 2018 3:32 pm
Can you describe the processing you do Valery please?
Post by Valery »
All my efforts to formalize the work flow to a single stable sequence have failed. All depends of how good the initial recorded movie is, how noised it. All I can say is that I do use two instruments: Astra Image Pro 3.0 and Photoshop CS6. In AI I mostly use Maximum Entropy and LR deconvolutions. And a lot of intuitive steps - depends how the processing is going. Next season I will finally go with SSM - in hope to get better quality of recorded movies.
