Sun in CaK Lunt B600 + Omega filter
Post by Carbon60 » Sun Oct 28, 2018 1:22 pm
Inspired by others on this forum, I purchased an Omega CaK filter on ebay to use in conjunction with my Lunt B600. I know that this can be a bit of a risk as they are a somewhat variable in terms of quality and performance, but I thought it worth the risk.
Here are some images from yesterday and this morning. As we know, it's a pretty blank Sun, unfortunately.
Basler acA1920-155um camera
72mm f6 refractor
1.5x barlow FDs and 5x powermate for the closer views.
Omega filter mounted in a filter housing and screwed into the front of the barlow/Powermate.
Minimal ImPPG
Image20181028_CaK_FD_Mono_Omega_LuntB600 by Stuart Green, on Flickr
Image20181028_CaK_FD_Colour_Omega_LuntB600 by Stuart Green, on Flickr
Image20181027_CaK_LuntB600_Omega_Mono_x5 by Stuart Green, on Flickr
Image20181027_CaK_LuntB600_Omega_Colour_x5_clone by Stuart Green, on Flickr
I tried to do a side-by-side comparison, but the clouds had other ideas..... Here is a previous FD using the Lunt B600 alone.
Image20181020-CaK_FD_Mono by Stuart Green, on Flickr
There is a definite improvement over the Lunt module alone.
Last night was clear so I also spent a little time imaging the Moon.
Image20181028_Moon by Stuart Green, on Flickr
Thanks for looking.
A couple of additions (2.5x Powermate 2 pane mosaics).
Image20181028_CaK_FD_Omega_LuntB600 by Stuart Green, on Flickr
Image20181028_CaK_FD2_Colour_Omega_LuntB600 by Stuart Green, on Flickr
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
krakatoa1883
Re: Sun in CaK Lunt B600 + Omega filter
Post by krakatoa1883 » Sun Oct 28, 2018 2:01 pm
Really fine images, Stu. Have you noted any difference compared with B600 alone ?
Raf
My personal page on Google+
Post by MapleRidge » Sun Oct 28, 2018 5:18 pm
Hi Stu...
I hope you get more opportunity to compare the combinations!
Out of curiosity, is the Omega+Barlow installed before or after the B600 CaK module?
eroel
Post by eroel » Sun Oct 28, 2018 6:50 pm
Stu:
Beautiful clean and Sharp CaK images.
As for the Moon, very nice.
Post by Carbon60 » Mon Oct 29, 2018 6:55 am
Definitely an improvement with the Omega :)
Stu
NEQ6 Pro-mount
Post by Carbon60 » Mon Oct 29, 2018 7:00 am
Hi Stu...
Hi Brian,
B600 first, directly in the focuser, then the Omega which I mounted in a holder and screwed into the front of the Barlow.
Stu
NEQ6 Pro-mount
Post by Carbon60 » Mon Oct 29, 2018 7:02 am
Stu:
Many thanks, Eric. Maybe at some point I'll image some proms too :)
Stu
NEQ6 Pro-mount
Post by Carbon60 » Mon Oct 29, 2018 7:04 am
TheSkyBurner wrote:
Sun Oct 28, 2018 9:31 pm
looks like you won the lottery with that omega filter.
Hi Apollo, yes, I might have hit lucky with this one, although it isn't 'extremely 2A' as advertised, but it seems to work.
Stu
NEQ6 Pro-mount
Post by marktownley » Mon Oct 29, 2018 9:35 am
Looks a positive improvement with the Omega there Stu. Good results.
Post by Montana » Mon Oct 29, 2018 10:53 am
I am sure I see a couple of Apollo ferrets in the top two images. Looks nice Stuart, I wonder what it would be like at high res. How much light does the filter cut out? just thinking of exposure length for hi res.
Post by ffellah » Mon Oct 29, 2018 11:24 am
Very nice results, Stu
Post by MapleRidge » Mon Oct 29, 2018 10:42 pm
Thanks for the filter sequence info!!!
p_zetner
Post by p_zetner » Tue Oct 30, 2018 2:18 am
Very nice, Stu.
I agree with you. The Omega filter gives some contrast improvement in my system as well. Maybe it does a slightly better job than the Lunt blocking filter in suppressing neighbouring etalon modes. Looks like your filter uniformity is good.
Peter
Users browsing this forum: No registered users and 35 guests
