Quiet Disc Today | HA | Oct 28th
MalVeauX
Post by MalVeauX » Sun Oct 28, 2018 5:25 pm
Heya,
Woke up to a clear, blue sky and was really excited, as I've had clouds most mornings. I got out a little late as we slept in this morning. At first, it seemed ok, at the full disc scale. The moment I moved over to the large scale, I noted the seeing was terrible. Really bad. I struggled to get anything at large scale. Great transparency, clear, blue sky. But yet the seeing was just horrible. It's a very quiet disc today. The large filament is gone. No visible spots. No action regions really (very, very minor looking one that is undesignated maybe). Two fair prominences on the limb, but very feint. And for giggles, just a random spot on the chromosphere surface to see if I could get through the horrible seeing at large scale and see decent spicules, since there's always at least something to see in HA at higher resolution.
Celestron 150mm F8 Refractor + Daystar 150mm ERF + Baader UV/IR Block Filter + Quark + ASI174MM
PST + 1.5x Barlow + ASI174MM
eroel
Re: Quiet Disc Today | HA | Oct 28th
Post by eroel » Sun Oct 28, 2018 6:48 pm
Marty:
Beautiful clean and Sharp shots.
Best regards, here it is cloudy. :-((
Post by MapleRidge » Mon Oct 29, 2018 12:11 am
Hi Marty...
The full disk is nice and sharp and the higher resolution images look good despite the seeing you had. These turned out quite well :bow
All cloud the last few days, and woke to the first snow covered landscape today :shock:
Hope for some sun on Tuesday if the forecast is half right.
ThomasHu
Post by ThomasHu » Mon Oct 29, 2018 4:24 am
hi Marty:
Beautiful shots.
And I'm interesting in which 1.5x Barlow do you use?
Thomas
Post by marktownley » Mon Oct 29, 2018 9:37 am
Really nice results Marty!
Post by Montana » Mon Oct 29, 2018 11:59 am
The hi res images are really very nice indeed, certainly very beautiful to look at even if quiet. We must be patient and enjoy these small spicules at this time :bow
MalVeauX
Post by MalVeauX » Mon Oct 29, 2018 1:20 pm
Hello!
I used a standard GSO 1.25" 2x barlow and unscrewed the lens off the barrel and screwed that lens directly onto the nose of the camera. I took two images and scaled them and it was approximately 50% the size, so I knew I was in the 1.5x ballpark. This is the cheap method and it works. A more costly way to do it would be to get one made from Siebert Ooptics (http://www.siebertoptics.com/SiebertOpt ... ml#Ad%201b). But again, I just used a shorty GSO 1.25" 2x barlow lens and screwed it on and it did the same thing (I had read about it and tried it).
ThomasHu
Post by ThomasHu » Mon Oct 29, 2018 1:27 pm
Hello!
Dear Marty,
Thank you so much!!
Users browsing this forum: Bing [Bot] and 9 guests
