Focus without the wobbles
denababy
Post by denababy » Fri Nov 02, 2018 4:11 pm
Hi here I am again. I hope you can help me as always, I am thinking of getting an auto focuser, the type powered by a small battery. When I adjust the focus the scope dances around and takes a moment to settle down, although not a major problem I can overcome this issue by fitting an auto focuser, but which one for my Explore Scientific ed80. I have tried the scope on both my mounts (eq3-2 and AVX) but the results are the same. It, the auto focuser, must be easy to fit, reliable and accurate. Anyone advise please.
Re: Focus without the wobbles
Post by MapleRidge » Fri Nov 02, 2018 10:57 pm
Dena...
I think you refer to a motorized focused as opposed to autofocus. Adding a motor is usually pretty easy and removes finger induced jiggles making focusing quite easy. I used JMI units for years until I started to upgrade the entire focuser to Moonlite which includes integrated motors. Quite a step up n cost too.
I’m sure there are other companies offfering motor kits as well, but I can’t recommend a motorized unit enough. They make focusing so much easier.
Post by Merlin66 » Sat Nov 03, 2018 12:14 am
I have and use various ED80 scopes (as well as the spectroheliograph) and on all of them I've fitted the SkyWatcher electronic motor (Identical to the Orion motor). Works 110% for me.
I use a 100 tooth 6mm wide XML timing belt, 30 tooth pinion to drive the 10:1 focuser knob. Gives good and reasonably precise control.
Highly recommended.
SW motor on PST mod
(To allow the focus motor to be controlled from the inside office I have a 4mtr four wire, RJ9 connector cable between the SW handcontroller and the motor.)
Post by MapleRidge » Sat Nov 03, 2018 3:12 am
Looks like a great setup to motorize the focusing Ken!!!
Users browsing this forum: denababy and 9 guests
