Heya,
Woke up to total fog cover, clouds and humidity. But, around 1pm Eastern, I was able to see through some sucker holes. Seeing wasn't very good, but it was good enough to attempt large scale. There's a new sunspot that looks like a small active region, but it's definitely a sunspot, a dipole, with two visible umbra that I resolved with a 150mm aperture. Some fairly large prominences are on the limb too. This sunspot is pretty interesting because it's such a high latitude on the solar disc in a region that sunspots of the 24th cycle really shouldn't be around. Maybe this is a sign of cycle 25?
Sunspot:
Proms:
Full Discs:
Earth Scale:
Setup:
Celestron 150mm F8 Refractor > Daystar 150mm ERF > Baader UV/IR Cut Filter > Quark Chromosphere > ASI174MM
PST > 1.5x Barlow > ASI174MM
New Sunspot (Undesignated ATM), Big Proms, Full Disc | HA | Nov 9th 2018
- Has thanked: 1171 times
- Been thanked: 1360 times
- solarsetup_11092018.jpg (34.84 KiB) Viewed 1125 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: New Sunspot (Undesignated ATM), Big Proms, Full Disc | HA | Nov 9th 2018
Another fine set of images, Marty. Looks promising for the start of the 25th, or maybe it’s wishful thinking . We need some hope that things are starting to turn around.
- Has thanked: 20424 times
- Been thanked: 10243 times
Super shots Marty! The spot is reversed polarity (compared to cycle 24 spots) so is part of cycle 25.
- Has thanked: 17667 times
- Been thanked: 8787 times
A fantastic set Marty, what a lovely little spot
