Today's SUN (20181116) with good seeing
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2018-11.html
Great seeing today and a nice small AR. Tried the SM90II again and got better results.
Check out the HR WL images with the TEC140 (X5 Powermate)
Solar Imaging Session (20181116) | Pedro RE'
TV101, LUNT60, TEC140
GS3-U3-28S4M, GS3-U3-28S5M
Takahashi EM-400
TEC140, BF30, GS3-U3-28S5M
H-alpha Full Disk (four-pane mosaic)
TEC140, GS3-U3-28S5M
HR, WL, X5 Powermate
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
OBSERVATORIES (DJI INSPIRE ONE)
SUN (20181116) H-alpha. TEC140 F/7, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5, four-pane mosaic
SUN (20181116) HR WL. TEC140 F/7, X5 Powermate, PGR GRASSHOPPER 3 GS3-U3-28S5
SUN (20181116) H-alpha DISK & PROMS (09:30 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
SUN (20181116) H-alpha DISK & PROMS (09:30 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
SUN (20181116) CaK PROMS (09:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20181116) WL, CaK & H-alpha (09:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPE 3 GS3-U3-28S4M
WEBLINK:
Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
Pedro Re'
- Has thanked: 1188 times
- Been thanked: 1382 times
- pedro
Re: Today's SUN (20181116) with good seeing
Thanks guys
Check out the artificial flat-field corrected moisaic image (TEC140 - four-pane mosaic)
- sun_TEC140_20181116_GS3-U3-28S5M_SM90II_Ha_mosaic_color_new.jpg (1.34 MiB) Viewed 2444 times
Pedro Re'
- Been thanked: 4427 times
Hi Pedro...
Very sharp images with all setups...excellent work
The artificial flats produced a very even image as well.
- pedro
Thanks again guys
The artificial flat field is described here:
http://re.apaaweb.com/image_processing.html
ARTIFICIAL FLAT-FIELD (SUN)
Open mosaic image (16-bit TIFF file) http://re.apaaweb.com/flat_field_sun-01.jpg
Create a new Layer http://re.apaaweb.com/flat_field_sun-02.jpg
Create a Mask http://re.apaaweb.com/flat_field_sun-03.jpg
Copy mosaic image to Mask
Apply a Median Filter (e.g. radius 25) http://re.apaaweb.com/flat_field_sun-04.jpg
Reduce Mask brighthness (Curves) http://re.apaaweb.com/flat_field_sun-05.jpg
Apply Mask (Difference) http://re.apaaweb.com/flat_field_sun-06.jpg
Reduce Mask Opacity if needed http://re.apaaweb.com/flat_field_sun-07.jpg
Flaten Layers
Use Curves and/or Levels to adjust contrast and brightness http://re.apaaweb.com/flat_field_sun-08.jpg
Save flat-field corrected image (16-bit TIFF file)
Before/After http://re.apaaweb.com/sun_20111226_LUNT ... before.jpg
Flaten Layers
Pedro Re'
- Has thanked: 8558 times
- Been thanked: 8290 times
Another nice collection, Pedro. Lovely WL images with wonderful granulation texture.
- Has thanked: 20813 times
- Been thanked: 10484 times
That is an excellent set of images Pedro! Clear skies here too, but sun is low in the trees on the roofline for me this time of year.
- pedro
Thanks Mark & Stu
It's raining here and you guys have the sunshine (low sun though)
best regards
best regards
Pedro Re'
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Excellent images, Pedro, thanks for detailing the flat field procedure, very useful.
- pedro
Thanks Raf and thanks Mark for the SPOD
I guess you're right, this might well be the last AR of this cycle, or maybe not
Pedro Re'
- Has thanked: 9318 times
- Been thanked: 6156 times
An excellent session and well deserved SPOD, Pedro !
- Been thanked: 4980 times
Pedro:
Super presentation and shots.
Thanks for the info concerning the flat.
Abrazo,
Abrazo,
- pedro
Thanks again guys (Eric & Franco)
Pedro Re'
- Been thanked: 8906 times
Fabulous set Pedro and really nice granulation which make for an excellent SPOD
- pedro
Thanks a lot Alexandra
Pedro Re'
