If using a Combo Quark on a refractor where in the chain of optics should my telecentric barlow(s) go? I would be using a rear mounted uv/ir filter for energy rejection.
Are there any problems with using a combo quark on a refractor other then getting the f ratio in the right range with barlows? Obviously the 2 degree SCT snout for the combo wouldn't be used with a refractor.
Cheers and thanks in advance,
Chris
Combo Quark on Refractor
- c8er
- Has thanked: 4 times
- Been thanked: 9 times
Solar Ha setup: Daystar Ha Quark, APM 140/980 refractor, Coronado SMII 60 DS BF15, McDougall Solar AutoGuider. Skywatcher ST80, Orion ED 80, WO ZS66 SD, and Nova 102mm f/6.5 achromat refractors.
Other scopes: C8,C11, ES Comet Hunter Mak-Newt, on 10Micron GM1000HPS, Celestron AVX, 8SE, CG-5 and Skywatcher Solarquest mounts.
Cameras: Celestron Neximage Burst Mono, ZWO ASI294MC Pro, AS120MC, ASI174MM, ASI290MC, Canon 60D, Celestron Nightscape CCD
- Has thanked: 20828 times
- Been thanked: 10499 times
Re: Combo Quark on Refractor
Telecentric needs to go inbetween the refractor and quark. UV/IR filter would go on the nose of the telecentric.
- c8er
Many thanks for that Mark.
