Good morning, everyone,
under a cirrusy sky (the clouds finally arrived last night:( ), a small sun of today with the fs60, sm40 double stack, glasspath x1.25, BF10 and zwo178mm around 12h10 UT still from the Sirene observatory on the Albion plateau (France)
I realized that I have a flat problem (like yesterday, by the way); I have to be more careful for the following times (if I see the sun tomorrow then )
cordially,
stephane
halpha sun of January 4th
- stef41
- Has thanked: 124 times
- Been thanked: 1491 times
- Been thanked: 8907 times
Re: halpha sun of January 4th
A bit smudgy but that doesn't notice when you view the Sun at original size glad you are having fun
- stef41
precisely in the original size: there are many streaks near the active area.
Thank you for your appreciation anyway
cordially,
stephane
cordially,
stephane
- Been thanked: 4434 times
Hi Stephane...
A good set of images, and if you can clean them up in the future it will make good images great!
Fill disk flats are hard to do, good luck !!!
- Has thanked: 20823 times
- Been thanked: 10498 times
Another great full disk Stephane! Why are you running flats with a full disk? Are you getting newtons rings from the camera?
- stef41
thanks for the comments:)
I no longer have a problem with newton rings because of the glasspath (I put a tilt ring) but I still have a problem with the 178mm halpha pattern! (this is a defect of this camera : viewtopic.php?f=4&t=20972 ). So I still need the flat.
cordially,
stephane
cordially,
stephane
