Ca K and G band images take on July 1 and 8, 2018
christian viladrich
Post by christian viladrich » Fri Jan 04, 2019 8:42 pm
Dear All,
I still have some images taken on 2018 waiting for processing. Here are some of them. The solar activity was not much higher than now :-(
The seeing was quite good on July 1, 2018 :
Here are close-ups on the chromospheric network and inverse granulation near the center of the solar disk :
An image of the limb was taken with the 300 mm Newtonian and a G band filter on July 8:
Best regards
Christian
http://www.astroplanetes.com/
MalVeauX
Re: Ca K and G band images take on July 1 and 8, 2018
Post by MalVeauX » Fri Jan 04, 2019 10:29 pm
Lovely G-Band Christian!
Post by ffellah » Fri Jan 04, 2019 11:00 pm
Beautiful images, Christian, thank you for sharing...
FMEnage
Post by FMEnage » Sat Jan 05, 2019 2:10 am
Fine details and processing ! Christian
-Mike
Post by MapleRidge » Sat Jan 05, 2019 3:47 am
Very sharp Christian...well done :bow
christian viladrich
Post by christian viladrich » Sat Jan 05, 2019 10:23 am
Thanks to all :-)
Christian
Post by marktownley » Sat Jan 05, 2019 10:46 am
These are excellent Christian! What focal length are you running at with the 2 closeup CaK shots?
christian viladrich
Post by christian viladrich » Sat Jan 05, 2019 5:23 pm
Hello Mark,
The focal length is close to 3000 mm.
Post by marktownley » Sat Jan 05, 2019 6:40 pm
Thanks Christian. What are your experiences of the ZWO290M as a camera for solar?
christian viladrich
Post by christian viladrich » Sun Jan 06, 2019 11:10 am
Thanks Pedro :-)
Mark, regarding the ASI290, the S/N max is 6.9 bits while it is 7.5 bits for the IMX174. So, in situations where there is a lot of light (e.g. use of an Hershel wedge), the IMX 174 will give better results.
In Ca K, light could me missing. I had some good results with the ASI290 on Venus in UV and on the Sun in Ca K. Still, I have not done extensive tests comparing ASI290 and the IMX 174.
On another hand, the small pixel size of the ASI 290 is a problem in Ha when using mica-spaced etalon since we need to reach F/30.
eroel
Post by eroel » Sun Jan 06, 2019 4:26 pm
Christian:
Super CaK and G band shots.
Post by Montana » Mon Jan 07, 2019 10:04 am
Absolutely wonderful shots :bow :bow :hamster: I have been doing some Christmas processing to clear the hard drives as well :)
What CaK filter do you use as I have not heard of this brand before?
Users browsing this forum: Bing [Bot] and 4 guests
