i hesitated in posting this image as the seeing did not support the 4600mm focal length but since AR2732 was slipping away I reconsidered. They can't all be masterpieces. Taken with the Quantum 6, 2x telesentric, Solar Spectrum and Daystar Combo stack. This is a two panel image reduced to 75%.
Phil
Jan 4, 2019 AR2732
- Been thanked: 10489 times
Re: Jan 4, 2019 AR2732
That came out very well Phil.
- Been thanked: 4980 times
- Been thanked: 4427 times
Great image Phil...no reason to hesitate at all
Data is data and all is important, we can't have perfect seeing every time. This is still a magnificent shot!
