New AR. is it the sign of the new cycle?
Does anydoby know is the new AR a sign of a new cycle?
- Has thanked: 20435 times
- Been thanked: 10243 times
Re: New AR is a sign of a new cycle?
No, sorry, equatorial based as opposed to higher latitudes. Same polarity as cycle 24 too. Look latitudes 40 degrees for the start of cycle 25 spots.
More detail - given solar cycle 24 peaked in the (solar) northern hemisphere in november 2011 and (solar) southern hemisphere peaked in february 2014, it would be reasonable to assume solar cycle 25 would start in the (solar) northern hemisphere first, so, this is the region you would look first, and, indeed is where we have already seen the first spots of cycle 25 back end of last year.
Just my theory here, but with cycle 25 forecast to be weaker than 24 (and 23), I would suggest that the time span between the offset peaks of the northern and southern hemisphere to be greater than previous cycles. This would make the smoothed cycle average appear lower than previous cycles, even if individual hemispherical peaks aren't much less than normal. This would tie in with all the predictions of cycle 25 being weaker than previous cycles as these predictions are based on the smoothed cycle average. I feel cycle 25 is a cycle of 2 halves...
Thanks, Mark for your point of view.
- Been thanked: 4340 times
Re: New AR. is it the sign of the new cycle?
Derek...
Great review of the transition from one cycle to the next...wasn't aware the hemispheres were not linked!
- Has thanked: 8415 times
- Been thanked: 8161 times
Interesting, Mark.
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Interesting stuff
David
