Hello all: the sun showed up this afternoon but it was literally traveling through the top of the trees from the only position at the property where I could shoot from. Please pardon the shadows and unevenness of the image but I could not refrain from imaging this very interesting and complex sunspot group. The jetstream was not helping either, so the conditions were difficult but it was still fun to see the sun.
Hopefully better conditions will come soon for all of us...
Clear skies to all.
AR2733 in the trees
- Has thanked: 9387 times
- Been thanked: 6199 times
AR2733 in the trees
- AR2733 final mono 600.jpg (188.34 KiB) Viewed 1322 times
- AR2733 final color 600.jpg (259.89 KiB) Viewed 1322 times
- Jetstream US 012619.jpg (1.5 MiB) Viewed 1322 times
- ES 152mm refractor.jpg (1.29 MiB) Viewed 1322 times
- Has thanked: 65 times
- Been thanked: 4460 times
Re: AR2733 in the trees
Hi Franco...
Good to see you caught some sun today...great results
The jet stream affected you more than I based on the map but seeing was very poor none the less.
- Has thanked: 20957 times
- Been thanked: 10589 times
Nice capture given the foliage Franco. I have the same problem as you this time of year.
Thank you Stu and Mark for your comments. I processed another image.
- AR2733 final mono 2 L 600.jpg (116.29 KiB) Viewed 1287 times
- Been thanked: 5016 times
- Has thanked: 8588 times
- Been thanked: 8324 times
Nicely done, Franco.
It’s so frustrating at this time of the year; low sun, poor seeing, trees......
You did well
You did well
Hi Eric and Stu: thank you for your nice feedback. I am planning on attending NEAF: I usually go on Saturday, hope to see you there. Let's make arrangements as we get closer to the date. Hopefully Brian, Rainer and maybe others will be able to come.
Nice images, Franco. Your scope sure is pointing low in the sky now. I'll bet it worries the neighbors.
Phil
Phil
- Has thanked: 18105 times
- Been thanked: 8941 times
Gosh, your grass is very brown for this time of year? lovely images of the AR though and I am glad you got a gap
Thank you, Phil and Alexandra, for your feedback. Phil: yes, my neighbors are very concerned when they see my scope this low . Alexandra: we definitely have some lawn work to do this spring.
