Woke up to a clear sky, yet it was cloudy and rained all night. I'll take it! I figured I would miss out on AR2733 as it rounds the limb. I really like limb spots in general, some of my favorite angles to look at the regions around the spot. AR2733 is pretty active and is the most interesting spot we've had in quite a while as we approach the peak of the minimum. There are some small filaments, a second undesignated region with some minor activity and some feint but large proms around the limb. Hoping to see AR2733 tomorrow as it begins to round the limb. there seems to be a wee filament in front it that may make an interesting prominence tomorrow or the day after as it begins to hit the limb.
B&W:
Colored:
Equipment:
Celestron 150mm F8 Refractor + Daystar 150mm ERF + Baader 50mm UV/IR block filter
Daystar Quark Chromosphere + PST Etalon
ASI174MM + 0.5x Focal Reducer
Orion ST80 (masked to 60mm) for the full disc mosaic & wider FOV of the AR
AR2733 & Proms at 150mm, Disc at 60mm | HA | Jan 28th 2019
- Has thanked: 1179 times
- Been thanked: 1369 times
- Has thanked: 20738 times
- Been thanked: 10439 times
Re: AR2733 & Proms at 150mm, Disc at 60mm | HA | Jan 28th 2019
These are excellent Marty, the second one is my favourite.
- Has thanked: 17925 times
- Been thanked: 8891 times
Wow! these are gorgeous I too had thought number two was my favourite
- Been thanked: 4407 times
Hi Marty...
These are all excellent, and I really like the 3-D appearance of the second image as well. The proms were faint but you kept the fine structures in the capture and processing. Well done all round
- MAURITS
- Has thanked: 2462 times
- Been thanked: 4878 times
