I woke up to pleasantly decent seeing and clear skies this morning. I started imaging AR2733 as it was rounding the limb around 9:30am with the sun at 23 degrees approximately. I imaged both in 656.28nm & 395nm (white light, UV continuum A) to see the difference at this wonderful angle on the limb with a 150mm aperture.
B&W:
Colored:
Equipment:
HA:
Celestron 150mm F8 Refractor
Daystar 150mm ERF
Daystar Quark Chromosphere + PST Etalon
ASI174MM + 0.5x Focal Reducer
WL:
150mm F8 Refractor
3x Barlow (F24)
Baader 2" Blue CCD IR-block filter (ERF)
395nm Filter (UV-A)
ASI174MM
AR2733 Rounding the Limb at 150mm HA & UV-A | Jan 29th 2019
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 20784 times
- Been thanked: 10476 times
Re: AR2733 Rounding the Limb at 150mm HA & UV-A | Jan 29th 2019
Good images there Marty!
- Has thanked: 9313 times
- Been thanked: 6151 times
- Been thanked: 4976 times
Marty:
Some super shots.
Some super shots.
I am quite impressed with the progress Marty developed last several months. And it is obvious than now his limiting factor is the resolution. And I hope that in a near future even his new 8" aperture will start to limit him. With Florida seeing he, as I am sure, can rise the bar on a new height in amateur imaging of our sun.
Go ahead, Marty!
Go ahead, Marty!
- Has thanked: 2464 times
- Been thanked: 4880 times
These are terrific Marty it certainly looks good on the limb
- Been thanked: 4425 times
These are excellent images Marty...superb work
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
- Has thanked: 8556 times
- Been thanked: 8287 times
Very nice indeed, Marty. You’ve come along in leaps and bounds, as we say. Lovely images.
