AR2733-Jan 29 and 28 2019
Astrophil
Been thanked: 581 times
Post by Astrophil »
Here are my over processed contributions of AR2733 before it falls off the limb.
The first is from January 29th and the second is a cropped version from the 28th.
Phil
Quantum 6 and Solar Spectrum
Has thanked: 1179 times
Been thanked: 1369 times
Re: AR2733-Jan 29 and 28 2019
Post by MalVeauX »
Very nice Phil!
Has thanked: 20743 times
Been thanked: 10439 times
You're treating us to some really excellent images here! Glad the sun is shining for you!
Been thanked: 4957 times
Post by eroel »
Phil:
Super shots.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Lovely image Phil ..
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
The first image is at the extreme edge of 6" aperture resolution!
Valery wrote: Wed Jan 30, 2019 6:57 am The first image is at the extreme edge of 6" aperture resolution!
Indeed! I think your seeing conditions must be spot on!
Has thanked: 17925 times
Been thanked: 8892 times
WOW!! :bow :bow these are scrumptious!
Astrophil
Post by Astrophil »
Thanks for all the replies and comments. We all know that seeing is everything but a little luck helps as well. When recording the videos, I didn't think the seeing was anything exceptional and seemed to fluctuate between slow undulations and high speed vibrations. It was clear most of those two days. Many videos were captured in hopes of catching a calm period. I guess it worked.
After many days of tuning and tweaking the alignment of the Solar Spectrum etalon, I found that double stacking with the Quark Combo has resulted in very uneven field illumination and long exposure times. The resulting images were unsatisfactory with the seeing conditions.
The single stack allowed for < 5 ms exposures, using a focal reducer, 50% histogram, and a higher contrast gamma setting. Still only 28 fps. Processing in imppg could be altered from the norm with lower sigma settings and higher iterations. Lower sigma and higher amounts of unshared masking as well. In a photo editing program a gradient mask was applied and the usual curves and levels adjusted. A slight de-noise mainly to highlights seemed to help avoid the way over processed look. Then again it might have just been a good image stack to begin with.
Thanks again,
Phil
Has thanked: 8523 times
Been thanked: 8253 times
Great images, Phil. Lovely resolution. That's a heck of a set-up.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Very sharp set of images Phil...well done :bow
