AR2733-Jan 29 and 28 2019
Here are my over processed contributions of AR2733 before it falls off the limb.
The first is from January 29th and the second is a cropped version from the 28th.
Phil
Quantum 6 and Solar Spectrum
Phil
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Re: AR2733-Jan 29 and 28 2019
You're treating us to some really excellent images here! Glad the sun is shining for you!
- Been thanked: 4980 times
The first image is at the extreme edge of 6" aperture resolution!
Thanks,
Thanks,
Indeed! I think your seeing conditions must be spot on!
Thanks for all the replies and comments. We all know that seeing is everything but a little luck helps as well. When recording the videos, I didn't think the seeing was anything exceptional and seemed to fluctuate between slow undulations and high speed vibrations. It was clear most of those two days. Many videos were captured in hopes of catching a calm period. I guess it worked.
After many days of tuning and tweaking the alignment of the Solar Spectrum etalon, I found that double stacking with the Quark Combo has resulted in very uneven field illumination and long exposure times. The resulting images were unsatisfactory with the seeing conditions.
The single stack allowed for < 5 ms exposures, using a focal reducer, 50% histogram, and a higher contrast gamma setting. Still only 28 fps. Processing in imppg could be altered from the norm with lower sigma settings and higher iterations. Lower sigma and higher amounts of unshared masking as well. In a photo editing program a gradient mask was applied and the usual curves and levels adjusted. A slight de-noise mainly to highlights seemed to help avoid the way over processed look. Then again it might have just been a good image stack to begin with.
Thanks again,
Phil
Thanks again,
Phil
- Has thanked: 8558 times
- Been thanked: 8290 times
Great images, Phil. Lovely resolution. That's a heck of a set-up.
- Been thanked: 4427 times
Very sharp set of images Phil...well done
