Small scale rapid changes in the solar chromosphere. 280mm scope.
Post by Valery » Sun Feb 03, 2019 10:38 am
Hi all,
During all these boring solar minimum days we all looking for changes on the sun face, we awating new spots, new ARs.
But the sun ramains the same - almost featurless in small H-a telescopes. Not say about white light telescopes where the
sun's face just blank.
But let take a look at the sun's chromosphere through a bigger telescope, say, through a 280mm SCT equipped with a very
inexpensive H-a filter and full size DERF filter (for unwanted heat rejection) and fast video camera. Here, at a much larger scale,
we can see the sun with a resolution level not available before. When we observe the sun through small telescopes we can see
only large scale chnages with low time resolution. Now through a biffer scope we can see changes in small scale features.
Here are two photos taken through my trusty C11 and only two minutes apart. One can blink them to see how many changes can
be detected at such a level of detalization. Only two minutes apart!
Of course no such dramatic changes as in large sun spots groups and surrounding ARs, but stll much much more than can be
seen in small H-a telescopes even on a moderately active sun.
Thanks for looking and comments.
Valery Deryuzhin
Re: Small scale rapid changes in the solar chromosphere. 280mm scope.
Post by Montana » Sun Feb 03, 2019 12:56 pm
Thankfully spicules are always changing rapidly over 10 minutes :) this would make a great spot the difference game :hamster:
Post by marktownley » Sun Feb 03, 2019 1:13 pm
Yup, quite a bit going on. Would make for an interesting animation at this scale. Sadly such seeing is beyond me...
Post by MapleRidge » Sun Feb 03, 2019 1:31 pm
Great example of the details a large scope can pull out Valery. Nice work :bow
Post by Valery » Sun Feb 03, 2019 1:35 pm
The daytime seeing is quite different from the night seeing.
Before I dived in to high res solar H-a imaging, I too was absolutely sure I will never catch such a seeing. Now I know when I can image the sun at high res with good chances for such a seeing: in days after some period after rainy weather, mostly clear, 3 - 6m/sec wind except north wind, 20 - 35 degree above horizon. And I do not use a SSM !
What is important too:
1. Excellent telescope optics and a quality DERF.
2. Precise focus.
3. Additional small DERF.
4. Metal tube of the SCT.
5. Luminous H-a filter. Better is a really narrow one.
6. Fast and low noise camera. 150fps or higher.
7. Patiece in hunting for best seeig moments. Patience, patience and patience. Never give up! SSM should help a lot.
Astrophil
Post by Astrophil » Sun Feb 03, 2019 7:30 pm
Valery,
Very detailed images and excellent processing makes it easy to see the differences two minutes can make. A visual merge of the images show very little has remained stationary. This illustrates why video captures should be kept short at this scale.
Thanks,
Phil
MAURITS
Post by MAURITS » Mon Feb 04, 2019 1:57 pm
Excellent images Valery ...
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Post by Valery » Tue Feb 05, 2019 1:07 pm
Valery,
Thanks,
Phil
At a good seeing I usually use 10sec recording cadence, at average seeing - 15-20sec and at lower seeing - up to 35sec.
Post by Carbon60 » Wed Feb 06, 2019 8:40 pm
Very nice images, Valery. The more you look the more you see...... lots going on.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by Valery » Sun Feb 10, 2019 7:52 am
Thanks, Stu.
This year I will try image timelapse movies of the sun at high res. May be with 14" aperture.
But at least with 12".
Post by marktownley » Sun Feb 10, 2019 8:09 am
That would be good Valery
Users browsing this forum: xn44 and 10 guests
