High res images in 3bands Aug 21 and 25, 12" aperture.
Hi all,
Here are four images I took last summer during tests of new 305mm (312mm outside diameter) DERF filters.
Filters were tested in a front of my C14 telescope.
First three images were taken in Ca K, in Ha and at 393nm continuum (10nm bandwidth).
The fourth image was taken August 25 in Ha.
Thanks for looking.
Valery Deryuzhin.
Thanks for looking.
Valery Deryuzhin.
- CaK image
- AR21719-2018-Aug-21-UT-7h24m-300mm-Ca-K.jpg (496.56 KiB) Viewed 326 times
- 393nm 10nm bandwidth image
- AR21719-2018-Aug-21-UT-7h35m-300mm-393nm.jpg (499.39 KiB) Viewed 326 times
- H-a image
- AR21719-2018-Aug-21-UT-7h44m-300mm-Ha.jpg (498.33 KiB) Viewed 326 times
- H-a image August 25
- AR12720-2018-08-25-UT06h45m-300mm+ARIES-312mm-DERF.jpg (496.44 KiB) Viewed 326 times
Re: High res images in 3bands Aug 21 and 25, 12" aperture.
Valery:
Superb shots, specially the CaK and the Continuum.
These are great Valery! The umbra in the first image look burnt out?
Yes, it was burn out by me with a "curves" tool in the PS CS6.marktownley wrote: ↑Tue Feb 05, 2019 7:43 pmThese are great Valery! The umbra in the first image look burnt out?
Otherwise we will not see such a dynamic range for "surface" details.
Excellent images Valery...well done
Beautiful images Valery
Thanks guys!
I published these images (far not all my best) as the illustration of what can be achieved with alternatives to dedicated overpriced solar telescopes and filters. These results were achieved without travelling to high altitudes locations, so, in average location conditions at 1.5m above ground and 55m above sea level in the center of 400000 city, with a total cost (telescope + all filters) of about $6000. And a telescope can be used for all types of night observings. If we go down to 8" aperture, then total cost will drop to $3000 - 3500 and the results still be much better than with 80-100mm overpriced dedicated telescopes and filters.
Valery, this is high end imaging ...
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Maurits
There ever going to be any smaller ERFs you make commercially Valery? 4"? 6"?
140mm and 155mm were made. Two 155mm readily available for immediate purchase.marktownley wrote: ↑Wed Feb 06, 2019 10:10 amThere ever going to be any smaller ERFs you make commercially Valery? 4"? 6"?
Exceptional images, Valery. Stunning.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
NEQ6 Pro-mount
I do love your images
What sort of curve profile you using Valery? Share a screen grab of it?Valery wrote: ↑Tue Feb 05, 2019 9:37 pmYes, it was burn out by me with a "curves" tool in the PS CS6.marktownley wrote: ↑Tue Feb 05, 2019 7:43 pmThese are great Valery! The umbra in the first image look burnt out?
I agree your setup offers exceptional value for money. This year I will be going to a IMX174 chipped camera to get up to the 200fps level. I can get up to 110fps at the moment, so interested to see the difference in the faster frame rate. It's the seeing I struggle with so hopefully the extra fps will give better freeze factor!Valery wrote: ↑Wed Feb 06, 2019 6:19 amThanks guys!
- pedro
Great HR images, I love the resolution of the second image. Which filter was used? 393nm?, do you sell these filters
This is just a 10nm 393nm filter by Edmund + filter #2 from PST CaK.
Baader K-line filter will do the same. The key factors here not a filter. They are:
1. Optical quality (from DERF to OTA and barlow)
2. Seeing. SSM may greatly help.
3. Very fast and low noise camera.
Your south location will provide many good seeing days, I beleive. Much more than here at my location.
- pedro
Thanks VAlery
I will try to use my Baader K-line filter for HR work
- robert
Really good results, food for thought too!
Robert
Robert
Thanks, Robert. The thought is as simple as 2x2 - for high resolution you need a large aperture.
Pedro,
For HR work in the UV you need a well corrected telescope of a larger aperture. I think that 6" APO is barely acceptable for this task.
The most cost effective telescope for HR works accross available spectrum is a cheap second hand C11.
It is light and very compact.
Users browsing this forum: No registered users and 6 guests
