finally some sunshine but bad transparency. Setup the equipment again with the Quark and SolarMonitor software for testing.
Seeing conditions were not favourable but at least 1 image with a few faint proms.
Tried to make a mosaic, but for some reason never manage to stitch everything together. (Too big overlap?)
When making the flats discovered a bug in the SolarMonitor plugin. If you disconnect the monitor (with plugin still selected) FC does not save any images. I fixed that this afternoon an the new plugin is on github. (See also software section)
Paul
Feb-14
- Been thanked: 4971 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: Feb-14
Nice image and thanks for the software update!
- Has thanked: 17970 times
- Been thanked: 8904 times
Re: Feb-14
That's a great prominence I bet that bug gave you a few bad words when you found that out well done, you are very very clever to design this software
- Has thanked: 9307 times
- Been thanked: 6143 times
