Feb 14, 15 more testing
Here are a few shots using the Quantum Six and Solar Spectrum with more testing with the addition of a PST etalon. Adding a PST to the system is not easy and I have a lot of respect for those who have had success double stacking them.
Yesterday a region of increased activity crept over the limb and continues to make its way across the disk. Looks promising. Some small proms as well.
Phil
Phil
- Has thanked: 1190 times
- Been thanked: 1384 times
- Been thanked: 4981 times
Re: Feb 14, 15 more testing
Phil:
Superb shots, they look so 3D that one wants to touch them.
- Has thanked: 20825 times
- Been thanked: 10499 times
Lots of detail in these images Phil
- Has thanked: 9327 times
- Been thanked: 6163 times
I agree with Eric, very 3D results. Excellent detail also.
Well done,
Well done,
- Been thanked: 4434 times
Phil...
Great shots and I'd day the first inverted image looks very 3D indeed !!!
Thanks Marty, Eric, Mark, Franco, and Brian. Sometimes interesting things happen while testing.
Phil
Phil
- Been thanked: 8907 times
These look great! And you don't seem to be bothered by reflections and banding. So Solar Spectrum plus PST etalon is an interesting road!
Thanks Alexandra, I tried to keep them on the softer side. (Mainly to hide problems)
Bart, the PST is proving problematic and has been removed from the system for a while. A circular polarizer helped with the reflections but banding, distortion, and inconsistent tuning still remains. I will be asking for help soon. Thanks for the comments. A lot of cropping and extensive hand processing was applied to hide problems.
Phil
Phil
You did a very good job hiding these problems! Here is what I will be trying in a couple of weeks when doublestacking:
viewtopic.php?f=9&t=25524
