Heya,
Lots of clouds & rain lately, weird weather for Florida. But Florida is always weird. I saw some patches between some clouds and the fog broke, I managed to get just a wee bit of data between big clouds and then it was just shut down due to no more sucker holes. I got maybe 20 minutes of sky time I think. But it was sufficient and seeing was good. Today's filament still persists, and the plage around it is bright. There are 4 large prominences on the limb in each quadrant, but I was only able to get some time on one of them before the clouds took over.
B&W:
Colored:
Equipment:
ST80 (masked to 60mm) Refractor (full disc)
Celestron CR150HD (150mm F8) Refractor
Daystar 150mm ERF + Baaduer UV/IR Block Filter
Daystar Quark Chromosphere + PST Etalon
ASI174MM + 0.5x Focal Reducer
High Res Filament & Plage, Full Disc | HA | Feb 17th 2019
- Has thanked: 1171 times
- Been thanked: 1360 times
- Been thanked: 4904 times
Re: High Res Filament & Plage, Full Disc | HA | Feb 17th 2019
Marty:
Super session and shots, beautifully resolved.
- Has thanked: 20424 times
- Been thanked: 10243 times
Nice shots Marty!
- Has thanked: 8415 times
- Been thanked: 8161 times
Lovely filament and prom images, Marty.
Really nice Marty, looks like the FD's are working well also.
Phil
Phil
- Has thanked: 17667 times
- Been thanked: 8788 times
Some very delicate proms and the filament is very beautiful you did well through those clouds!
- Been thanked: 4786 times
- Been thanked: 4340 times
Another excellent session Marty, and I have to say I'm most impressed with the detail you are getting in these small proms
Seeing makes it or breaks it, and I'd suspect you are on the better side of the seeing equation
