Februari 19
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Februari 19
Post by MAURITS »
Telescope 150mm with Baader D-ERF, extensions, Quark chromosphere, 0.5x reducer and ASI 174 MM.
No newton rings to see (no tilter or eliminator used).
This is the first time that I have a recording all in one time.
The post processing from the surface and prominence is from the same recording.
At the first sight, all was oké.
The gray scale image is I think well, except the white ring around the edge (I don't know where this come from) ?
The color version is total different from my previous method, when I had two recordings (one surf. and one prom.), however with the same color settings. Hmm stranges results … but oké.
I don't know what the "fog" is around the edge ...???
I do believe that my Quark is a good one anyway. :)
zon gray.jpg (190.15 KiB) Viewed 1555 times
zon color.jpg (262.32 KiB) Viewed 1555 times
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
rsfoto
Has thanked: 9677 times
Been thanked: 5751 times
Re: Februari 19
Post by rsfoto »
Hi Maurits,
Great details on the images.
Rainer
Astrophil
Been thanked: 581 times
Re: Februari 19
Post by Astrophil »
Maurits,
Nice images. The surface texture looks good and the prom showed up well. The white ring (dreaded double limb) has been enhanced when the surface is inverted. This can be toned down some by adjusting the curves where it transitions to the inverted surface. The fog around the limb sometimes shows up when darkening the sky and trying to brighten the proms quickly. This can be minimized in processing. Also, Quarks for some reason can produce a fog or haziness on one side. Try rotating the Quark while keeping the cameras position fixed. I have marked my Quark so it's easy to position for the best prom capture. Sometimes sky conditions can result in the foggy appearance.
Phil
eroel
Been thanked: 4957 times
Re: Februari 19
Post by eroel »
Maurits:
Nice images.
Has thanked: 17888 times
Been thanked: 8887 times
Re: Februari 19
These are great and I am glad everything is working OK :bow
Sometimes the fog can happen if you have the gamma set too high or the sky conditions are slightly milky (not enough to see by eye).
Has thanked: 9280 times
Been thanked: 6125 times
Re: Februari 19
Post by ffellah »
Nice results, Maurits
Has thanked: 8523 times
Been thanked: 8251 times
Re: Februari 19
Post by Carbon60 »
Nice images, Maurits.
Stu
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Re: Februari 19
Post by krakatoa1883 »
NIce limb image and prom. Agree with Astrophil about the fog, I noted it depends much on sky conditions and on how much the brightness has been increased to show the faintest parts of proms. In most cases I am able to correct the problem during processing, but not always, sometimes I have to accept a compromise. Note that the focal reducers can increase this issue.
Raf
MAURITS
Re: Februari 19
Post by MAURITS »
Thanks a lot for the nice comments.
I will try an other processing sheme today from the same captures.
Maurits
MAURITS
Re: Februari 19
Post by MAURITS »
I have the above images again reprocessed.
I have attempted to improve the white border.
This is the same prom as before (images above), but I tweak out more details in Imppg.
Gray Sun.jpg (217.43 KiB) Viewed 1471 times
Color Sun.jpg (259.63 KiB) Viewed 1471 times
Maurits
Has thanked: 20738 times
Been thanked: 10428 times
Re: Februari 19
Missed this one. Great shots!
Has thanked: 64 times
Been thanked: 4406 times
Re: Februari 19
Post by MapleRidge »
Great images Maurits, and the adjusted processing cleaned up the images which helps cut the limb glare. Well done :bow
MAURITS
Re: Februari 19
Post by MAURITS »
Thanks all of you for the comments :bow
Maurits
