More aperture please (PST)
Astrophil
Been thanked: 581 times
Post by Astrophil »
Hi all,
Please bear with me for a while, I’m trying to get my moneys worth out of this new solar scope and justify its purchase. Double stacking was not satisfactory and a mod 2 was even less impressive, so my plan is to get the most out of imaging with the stock PST. This will be old news for most here so feel free to send some tips my way.
I have some lower power Barlows arriving this week that should help match the image size to the Grasshopper camera. A 2.5x Powermate is too much for a full disk in one shot and mosaics are time consuming. I did find that using a short snout on the camera will come to focus but the image is small. Anyway, here are my first attempts at full disk imaging with the PST.
The first uses a 2.5x Powermate and a focal reducer (don’t laugh).
Second and third is with the short snout on the camera only.
Forth is a four panel mosaic using the 2.5x.
Fifth Is a greyscale version. I like it the best.
Thanks,
Phil
Mosaic feb 23cc.jpg (455.72 KiB) Viewed 2596 times
Mosaic feb 23cm.jpg (395.05 KiB) Viewed 2596 times
Has thanked: 17925 times
Been thanked: 8891 times
Re: More aperture please (PST)
The last couple of pics are the absolute best you are going to get with a 40mm, these are cracking :bow
Has thanked: 20738 times
Been thanked: 10439 times
Nice shots! It's just about finding the correct spacing of the barlow to the chip to fill the fov.
bart1805
Been thanked: 1 time
Post by bart1805 »
4 and 5 are indeed beautiful! So please don't invest in a new barlow, but in time by making mosaics. (-;
Baader VIP barlow is really nice btw. You can change the distance by adding or removing T2 extensions.
One of these https://www.ebay.co.uk/itm/Short-C-Moun ... :rk:3:pf:0 and the nose off a 2x barlow should give you the image scale and focus you need to get a fuller frame.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Phil...
The FD's are good, and if you can get a barlow to boost the image scale a bit it will give you some great images.
The mosaics are very impressive but I agree they are a lot of work. For me, the FD on one frame are not meant to be super high-res, but a way to show the full disk and where features are relative to each other. Larger scopes can then be used to get the top end images.
Astrophil
Post by Astrophil »
Thanks for the suggestions and comments. This is definitely the right place to ask. I agree that FD images are more for an overview of what's going on but some of the disk images I've seen here were spectacular. It might sound odd but at times I like to try to get the most from the least. I've had interesting results from an iPhone and 89mm scope using mosaics. (Link below)
If we get any solar activity soon, I will try another mosaic and a full frame disk image for comparison. You all already know the results but I want to see for myself.
Mark, thanks for the short c-mount link. I'll get one.
Reflected sunlight mosaic with small scope and phone
http://www.astrophil.com/astrophotos/iP ... n=download
Phil
Christopher
Has thanked: 33 times
Been thanked: 34 times
Post by Christopher »
Astrophil wrote: Wed Feb 27, 2019 12:11 am It might sound odd but at times I like to try to get the most from the least. I've had interesting results from an iPhone and 89mm scope using mosaics. (Link below)
I know exactly what you mean Phil. I’m working on a similar project pairing up a SolarMax 40 with a Borg 45ED and iOptron SmartEQ Pro. Mount and scope together weigh what my Lunt 100 weighs unmounted. I’m thinking quick frame grabs when short on time and ultra-portability. But part of me is very focused on just achieving a satisfying result using a “minimalist” approach - if we can say it with a straight face 😐. I’d say you’re definitely on track to squeeze the most out of that PST. The B&W looks very nice. Love the cellphone moon shot also. I also have a Grasshopper and use that short c mount with just the nosepiece of a Coronado 2X Barlow. It works well. I’m interested to see your further results. As I get my rig together and get some sunshine I’ll try and post some results as well.
Christopher
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Top serie Phil ...
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
eroel
Been thanked: 4957 times
Post by eroel »
Phil:
Your PST gives very good clean and even images, so the result you get with the 2.5 Powermate and a reducer at the camera nose gives a nice FD that can show what is going on the Sun, and if interesting you can make a FD mosaic or just a partial one of the interesting feature.
I use my 40mm Coronado etalons on a 76mm TeleVue, just to take FD´s, so when I see something interesting I make a mosaic or go for a bigger solar scope.
Try to get the best distance of the Barlow to the chip, so to get the best size possible for the used camera chip.
Beautiful clean and crisp mosaics shown.
Astrophil
Post by Astrophil »
Christopher, with a straight face...indeed.
Thanks Maurits.
Eric, good info. I have a plan to follow. We'll see what happens.
Phil
Christopher
And finally....here's my "minimalist" set-up with an initial result. As I mentioned above it is a Borg 45ED which I've had for many years with an older pre-Meade Coronado SolarMax 40 and the Solar Sprectrum modified T-scanner. All riding on a mighty iOptron SmartEQ Pro+ with nary a counterweight. Set-up and tear down are quick and easy. I don't think I'll be doing any close-up prom animations with this set-up but for a quick FD or super portable rig it ought to do the job. Not sure what that strange striped shading is across the top of the disk but I think I managed to get rid of it in a later shot by rotating the T-scanner.
Christopher
Looks a good result! a nice setup too.
Christopher
Thanks Mark! It occurred to me that this light path passes through elements created by David Lunt, Del Woods and Mark Wagner....arguably 3 of the most influential amateur H-alpha equipment makers in the U.S. Kinda cool. I failed to mention the shot was taken yesterday around 11:30 AM EDT.
Christopher
Astrophil
Post by Astrophil »
Christopher, that is some "minimalist" setup. All the good stuff in one small package. Very nice first image and they will improve with a little tweaking. Made in the USA, well how about that? Looking forward to seeing more.
Phil
Christopher
Thanks Phil. I think it's going to be a fun set up to use when time is limited which these days seems often. If we're going to credit manufacturer nations we'll have to include Japan (Borg) if we're stopping at the focus point :lol: I was able to rotate that shadow/reflection pattern out by turning the T-scanner relative to the front etalon. Here's another image from 14:04 EDT same session. A bit cleaner.
Christopher
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
Christopher,
You seem to have ended up with distinct banding across the whole disk????
Christopher
I'm not sure if you're referring to the fine horizontal banding or the two vertical shadowy ones. I think the latter could potentially be managed using flats. As for the horizontal stuff....yes. This is strange. I uploaded the exact same file to Astrobin and don't see those artifacts. At least not near as pronounced. I suspect it could be oversharpening and compression artifacts but I'm not sure. Also not sure why the same file renders differently.
Thoughts?
Here's the Astrobin image.
Christopher
Astrophil
Post by Astrophil »
Christopher, the second image looks better. The vertical band and the horizontal lines might vanish with the use of a flat. The fine lines look like what interlaced cameras produced so I tried a deinterlace filter to remove them. Not too much loss of detail. Sharpening tends to enhance them. Anyway, not very visible unless enlarged a lot. Keep up the good work.
Phil
Here is the de-interlaced version.
Christopher
Thank you for the de-interlace tip Phil. Extremely helpful. :bow2 I also found a video that had quite a bit of drift in it due to long pauses in adequate seeing so I was able to use AutoStakkert to smooth out the vertical banding as well. I think I'll stop here on this session. Many lessons learned :bow and I'm quite pleased with the result given the 40mm of aperture :P .
Christopher
