H-alpha, 25022019
H-alpha, 25022019
After all the CaK experiments back to H-alpha.
Baader D-Erf _ 150 mm f/8 Skwywatcher _ Baader Glasspath 1,25x _ Baader 35nm H-alpha _ PST-etalon A _ Lunt B1200 _ ASI290MM.
Stacked 100 images out of about 4.000 from half a minute. Did not use the SSM because I forgot that when you re-install FC, you also have to re-install other software..... Could get it running while looking at the sun.
The soft approach:
Jup_12252041258_imppgtest by bart moors, on Flickr
CS! Bart
The soft approach:
CS! Bart
- Has thanked: 8543 times
- Been thanked: 8278 times
Re: H-alpha, 25022019
Nice one, Bart. Lovely spicule fringe.
- Has thanked: 20779 times
- Been thanked: 10462 times
Yes great image indeed Bart!
- Has thanked: 17970 times
- Been thanked: 8905 times
- Been thanked: 4422 times
Looks good Bart...nice and sharp
Thanks all! Looking forward to the coming months with the sun higher in the sky.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- rsfoto
- Has thanked: 9710 times
- Been thanked: 5769 times
Wow, excellent image
Rainer
Rainer
- Has thanked: 9307 times
- Been thanked: 6144 times
Thanks Rainer and Franco!
When looking closely at the image, I think even this one is processed too much. The double limb has double lines, and that is not the outcome you want. Probably a bit too much LR deconvolution causes this. It will be cloudy this weekend, so time to try out a softer approach.
