(Sunspot!!) AR2734 & Full Disc in HA | March 6th 2019
- Has thanked: 1171 times
- Been thanked: 1360 times
Heya,
I haven't seen the sky for over a week with this dreadful weather lately here in Florida, literally just nothing. A cold front just blew in and over night it went from 80F+ and all rain and clouds, to dropping in the 30's F and 50~60's F during the day, along with it came a clear blue sky, no clouds at all, all day, and good transparency. The seeing was not as good, but, it was worth wrestling through it a bit. The seeing was decent from 9am to 10am, but it fell apart after that so I didn't get enough time to get good data on the one fairly bright prominence on the limb and could only do a single wavelength today as the seeing just didn't allow for anything else after 10am or so. Anyhow, we have a new sunspot! AR2734 received designation today and it went from a wee active region to showing a nice dipole with visible umbra and a little plage area between the poles and some tiny little filaments whirling around the field. It's so tiny still! On a full disc you could almost not see it without paying close attention. But, at larger scale, it comes to life nicely.
C8 + Quark
C8 + Quark + PST Etalon
Full Disc
Earth Scale
Equipment
C8 Edge HD SCT with Aires 200mm Tri-Band D-ERF & Baader UV/IR Block Filter (Edge 0.7x Focal Reducer utilized)
ST80 masked to 60mm Refractor + Baader UV/IR Block Filter + 0.5x Focal Reducer
Daystar Quark Chromosphere
PST Etalon
ASi174MM
C8 + Quark
Full Disc
Earth Scale
Equipment
PST Etalon
ASi174MM
Re: (Sunspot!!) AR2734 & Full Disc in HA | March 6th 2019
Beautiful images Marty. Glad to see the new system working so well. Now, if we ever get some good weather we can really see what that system can do!
Phil
Phil
- Been thanked: 4904 times
Marty:
Super session and a beautiful new setup.
- Has thanked: 20440 times
- Been thanked: 10246 times
Nice set of images there Marty!
- Been thanked: 4786 times
- Been thanked: 8791 times
These are cracking Marty
Not much calcium K recently, is there any reason for that?
- Has thanked: 9145 times
- Been thanked: 6025 times
Excellent images, Marty. All great, the first one is my favorite. 2734 is tiny but you succeeded in capturing it in great detail.
Thank you all,
I unfortunately don't have a CaK filter right now. I borrowed some in the past, but it's time to get my own. It's looking like I'll eventually get a Lunt Cak B1200 module and go from there. My hopes are to eventually double stack a pair.
- Has thanked: 8418 times
- Been thanked: 8163 times
Very nice, Marty. Nice to see some activity.
- Been thanked: 4340 times
An excellent session Marty...great detail with the Quark setup
