Today's Proms & Limb Filament, Full Disc, HA | March 13th 2019
Has thanked: 1179 times
Been thanked: 1369 times
Post by MalVeauX »
Woke up to total cloud cover again. So, good seeing was not an option. But, late this afternoon around 1pm, the sky cleared up. Seeing was poor, so I could not support a large image scale. I stacked reducers to lower my scale to be able to do anything in the poor seeing. But managed to get some data worth processing into images. There's an interesting filament and plage area on the limb rotating out of view. Mean while, there's also an interesting new plage area with some fair prominences rotating into the view. Included some small plages found mid way on the disc.
B&W:
Color:
Equipment:
C8 Edge HD + Aires 200mm Tri-band D-ERF + Baader 2" UV/IR Block filter
Edge 0.7x Focal Reducer + Quark Chromosphere + PST Etalon + ASI174MM + 0.5x Focal Reducer
ST80 masked to 40mm with same imaging train for full disc
Has thanked: 20755 times
Been thanked: 10441 times
Re: Today's Proms & Limb Filament, Full Disc, HA | March 13th 2019
Great images Marty! Pants weather for me today, hoping for some better skies on sunday...
pedro
Has thanked: 14 times
Been thanked: 6685 times
Post by pedro »
Nice new setup
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
Great setup and captures.
Our students saw that proms on a C8 fitted with an ARIES D-ERF + PST etalon + x2 barlow + ASI224MC. Previously they had seen the view on the same setup with an ASI 174MM. Here is a single frame image of that prom (I hope you don't mind showing this image on this thread).
Not that impressive as a single frame, but the students were thrilled to see the close-up live video of the Sun in colour.
Alfred
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Beautiful Marty, captures and setup.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Been thanked: 4958 times
Post by eroel »
Marty:
Very good shots and nice setups.
Has thanked: 17925 times
Been thanked: 8894 times
Great shots of the spicule forest Marty :bow
and great to hear your story with the students Alfred :hamster:
Post by MalVeauX »
yltansg wrote: Wed Mar 13, 2019 9:05 pm
No problem, always love knowing people are doing it themselves!
Maybe you can share any advice on how you used the PST etalon with the C8? I tried inserting a PST etalon with their collimating lenses and the black box attached in a Stage I mod, but I just couldn't find focus with it. This is with a C8 Edge HD. Not sure it is even possible or if it's the same or not the same as a standard C8. But was trying it just to see and evaluate the etalon on its own for re-purposing.
yltansg
Post by yltansg »
Hi Marty,
Sorry that I didn't reply earlier. I was too busy and didn't monitor solarchat.
You mentioned
[Maybe you can share any advice on how you used the PST etalon with the C8? I tried inserting a PST etalon with their collimating lenses and the black box attached in a Stage I mod, but I just couldn't find focus with it. This is with a C8 Edge HD. Not sure it is even possible or if it's the same or not the same as a standard C8. But was trying it just to see and evaluate the etalon on its own for re-purposing].
I used an old C8 (from a Nexstar 8). The PST etalon is placed (Stage 2 mod) immediate at the output of the C8. Valery had advised me that the PST etalon should be as close to the output of the C8. This is my setup:
I have not tried it with a C8 HD.
Alfred
Post by MalVeauX »
yltansg wrote: Thu Mar 21, 2019 1:40 pm Hi Marty,
You mentioned
Alfred
Thanks Alfred,
What adapter did you use to thread it as close to the cell as possible? I have the AOK Swiss adapters, but I have to insert it into a 2" visual back to do that, which probably costs me some distance.
yltansg
Post by yltansg »
Hi Marty,
I have it done at a local machine shop. Here is a close-up view of it:
Alfred
Post by MalVeauX »
yltansg wrote: Fri Mar 22, 2019 9:12 am Hi Marty,
Alfred
Thanks Alfred,
So likely, I won't be able to, I think the Edge C8 has a different focus range than a standard C8 due to its aplanar lens element. Too bad. Would have liked to test it.
yltansg
Post by yltansg »
Hi Marty,
I have a C8 Edge HD. Because of this same understanding (that I will not be able to achieve focus when using PST etalon), I have not tried it. Maybe I will do it just out of curiosity. Will PM you when I get to do it. Your images with Quark are amazing. I will consult you when I get to experiment with the quark. Take care.
Alfred
