Today's Proms & Limb Filament, Full Disc, HA | March 13th 2019
- Has thanked: 1171 times
- Been thanked: 1360 times
Heya,
Woke up to total cloud cover again. So, good seeing was not an option. But, late this afternoon around 1pm, the sky cleared up. Seeing was poor, so I could not support a large image scale. I stacked reducers to lower my scale to be able to do anything in the poor seeing. But managed to get some data worth processing into images. There's an interesting filament and plage area on the limb rotating out of view. Mean while, there's also an interesting new plage area with some fair prominences rotating into the view. Included some small plages found mid way on the disc.
B&W:
Color:
Equipment:
C8 Edge HD + Aires 200mm Tri-band D-ERF + Baader 2" UV/IR Block filter
Edge 0.7x Focal Reducer + Quark Chromosphere + PST Etalon + ASI174MM + 0.5x Focal Reducer
ST80 masked to 40mm with same imaging train for full disc
B&W:
Color:
Equipment:
- Has thanked: 20424 times
- Been thanked: 10242 times
Re: Today's Proms & Limb Filament, Full Disc, HA | March 13th 2019
Great images Marty! Pants weather for me today, hoping for some better skies on sunday...
- pedro
- Has thanked: 14 times
- Been thanked: 6573 times
Nice new setup
Pedro Re'
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Great setup and captures.
Our students saw that proms on a C8 fitted with an ARIES D-ERF + PST etalon + x2 barlow + ASI224MC. Previously they had seen the view on the same setup with an ASI 174MM. Here is a single frame image of that prom (I hope you don't mind showing this image on this thread).
Not that impressive as a single frame, but the students were thrilled to see the close-up live video of the Sun in colour.
Alfred
Alfred
- Been thanked: 4786 times
Beautiful Marty, captures and setup.
- Been thanked: 4904 times
Marty:
Very good shots and nice setups.
- Has thanked: 17648 times
- Been thanked: 8787 times
Great shots of the spicule forest Marty
and great to hear your story with the students Alfred
No problem, always love knowing people are doing it themselves!yltansg wrote: ↑Wed Mar 13, 2019 9:05 pm
Maybe you can share any advice on how you used the PST etalon with the C8? I tried inserting a PST etalon with their collimating lenses and the black box attached in a Stage I mod, but I just couldn't find focus with it. This is with a C8 Edge HD. Not sure it is even possible or if it's the same or not the same as a standard C8. But was trying it just to see and evaluate the etalon on its own for re-purposing.
- yltansg
Hi Marty,
Sorry that I didn't reply earlier. I was too busy and didn't monitor solarchat.
You mentioned
[Maybe you can share any advice on how you used the PST etalon with the C8? I tried inserting a PST etalon with their collimating lenses and the black box attached in a Stage I mod, but I just couldn't find focus with it. This is with a C8 Edge HD. Not sure it is even possible or if it's the same or not the same as a standard C8. But was trying it just to see and evaluate the etalon on its own for re-purposing].
I used an old C8 (from a Nexstar 8). The PST etalon is placed (Stage 2 mod) immediate at the output of the C8. Valery had advised me that the PST etalon should be as close to the output of the C8. This is my setup:
I have not tried it with a C8 HD.
Alfred
You mentioned
Alfred
Thanks Alfred,yltansg wrote: ↑Thu Mar 21, 2019 1:40 pm Hi Marty,
You mentioned
Alfred
What adapter did you use to thread it as close to the cell as possible? I have the AOK Swiss adapters, but I have to insert it into a 2" visual back to do that, which probably costs me some distance.
- yltansg
Hi Marty,
I have it done at a local machine shop. Here is a close-up view of it:
Alfred
Alfred
Thanks Alfred,
So likely, I won't be able to, I think the Edge C8 has a different focus range than a standard C8 due to its aplanar lens element. Too bad. Would have liked to test it.
- yltansg
Hi Marty,
I have a C8 Edge HD. Because of this same understanding (that I will not be able to achieve focus when using PST etalon), I have not tried it. Maybe I will do it just out of curiosity. Will PM you when I get to do it. Your images with Quark are amazing. I will consult you when I get to experiment with the quark. Take care.
Alfred
Alfred
