Sunday Sun 17th March '19
- Has thanked: 8559 times
- Been thanked: 8297 times
It has been one of those 'hit and miss' mornings as far as the weather goes. More misses than hits, with lots of heavy cumulus and small gaps and occasional showers. Luckily I managed to dodge the worst of it.
Here are a few shots with my Tecnosky 125mm/f7.8 APO Doublet fitted with a APM 2.7x Barlow from Astrograph + CaK Lunt B600 Module with Omega and Baader Cak-line filters mounted on the nose of the Barlow.
Basler acA1920-155um camera
Genika Astro capture
AS!3 stacking
ImPPG deconvolution
PixInsight colour
I'm still trying to find the optimum equipment set-up and processing settings. I hope these are not filled too much with artefacts from ImPPG.
20190317_Chromosphere_CaK by Stuart Green, on Flickr
20190317_Chromosphere_CaK_Colour by Stuart Green, on Flickr
20190317_Chromosphere2_CaK_Colour by Stuart Green, on Flickr
Mosaic
20190317_Mosaic_CaK_Colour by Stuart Green, on Flickr
and an inverted one....
20190317_Mosaic_CaK_Inverted_Colour by Stuart Green, on Flickr
Pushing the exposure I even managed to capture a looping prom.... a first for me in CaK.
20190317_Looping Prom_CaK_Colour by Stuart Green, on Flickr
Not the best quality image, but.....
Thanks for looking.
AS!3 stacking
ImPPG deconvolution
PixInsight colour
Mosaic
Thanks for looking.
- Has thanked: 20834 times
- Been thanked: 10503 times
Re: Sunday Sun 17th March '19
Nice results Stu! I managed a few shots before the hail showers set in.
- Has thanked: 1192 times
- Been thanked: 1387 times
Hi Stu,
Very nice CaK images with 125mm scope! You can easily rise the scale up at 2x and images will be only better! Now they are really undersampled.
Many thanks Mark/Marty/Valery.
Valery, I totally understand and agree. These were imaged just above my neighbours roof tops, between a tree and a lamp post with the threat of rain at any moment. Not ideal, so I figured I'd use the faster frame rate of the IMX174 chip rather than the IMX250 with smaller pixels, but somewhat slower capture rate. A bit of a compromise, but when the conditions improve I'll certainly be using the IMX250 as this is closer to the critical sampling scale with this set-up.
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
These look pretty good to me Stu. I love that little loop prominence shot!
David
- Been thanked: 4434 times
Hi Stu...
Your CaK images are very sharp, and nice to see that loop prom too
- Been thanked: 4981 times
- Been thanked: 8907 times
Wow!! look at that loop prom nice catch Stuart the others are beautifully done too
- Has thanked: 9327 times
- Been thanked: 6163 times
Many thanks Dave, Brian, Eric, Alexandra & Franco.
I appreciate your supportive comments.
- Been thanked: 4881 times
