Sunday Sunshine - 17th March
Has thanked: 20756 times
Been thanked: 10441 times
Weather forecast was for hail and thundery showers for today, however as is with such unstable air streams the day will start off bright and clear before all of a sudden the clouds bubble up with force. I was out setup and observing by 9am.
First off I went to the blue end and got some CaK in as I knew the seeing was only going to go downhill through the observing session.
First off the full disk, 60mm f15, homebrew CaK filter and the PGR GH3 ICX814.
Imagecak-60-fd-bw by Mark Townley, on Flickr
Imagecak-60-fd-colour by Mark Townley, on Flickr
I tried some closeups with the 100mm scope somewhere over 2000mm fl with the PGR CH3.
Imagecak-close-bw by Mark Townley, on Flickr
Imagecak-close-colour by Mark Townley, on Flickr
At the other end of the spectrum it surprised me how much there was to see when looking closer in Ha. First off the full disk with the SM90 and ICX814.
ImageHa-Full-Disk-bw by Mark Townley, on Flickr
ImageHa-Full-Disk-colour by Mark Townley, on Flickr
Then popping the Quark in the end to double stack for a look at the filament and plage from relic active regions:
ImageAR-closeup-Ha-bw by Mark Townley, on Flickr
ImageAR-closeup-Ha-colour by Mark Townley, on Flickr
Be sure to double click and view in flickr for the full size images. Pleased to get some sun this morning as it's now just wet again.
Has thanked: 1179 times
Been thanked: 1370 times
Re: Sunday Sunshine - 17th March
Post by MalVeauX »
Lovely captures Mark!
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Excellent images, Mark!
Your SM90II telescope looks like a keeper. And works even better with your Quark.
And CaK easily can be even better at about 1.5x larger scale!
Hope a good seeing came back.
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Nice set of images, Mark. I see you were rain/hail dodging like myself.
bart1805
Been thanked: 1 time
Post by bart1805 »
Nice one Mark, is going to be a pleasure to image with this scope when the weather is better / the sun is more active.
Thanks everyone! I was undersampling Valery, I need to look at a more powerful barlow for CaK, I end up stacking barlows at the moment if I want to get up to >f30 which the extra glass really has an adverse effect on light levels. My 2.5x barlow gives me a annoying ghost at 393nm which rules it out. I need to get a decent 3x barlow.
The weather was awful today after 11am Stu, at one point the ground was totally covered in hail. I do like the scope / camera combo i'm running at the moment, I just need the seeing to improve so I can use some bigger apertures.
David_The_Bears_Fan
Has thanked: 423 times
Been thanked: 167 times
Post by David_The_Bears_Fan »
Great set Mark. Didn't get chance for much more than a quick glance at white light today unfortunately.
David
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Mark...
These Ha and CaK images are excellent...well done :bow
Has thanked: 9296 times
Been thanked: 6131 times
Post by ffellah »
A very good session, Mark
Thanks everyone! Couple of extras here; the other limb in Ha showing a small prom and small plage area.
Imageother-limb by Mark Townley, on Flickr
Was running through my CaK data I shot, this one was by far the sharpest. I will endeavour to get a higher f ratio next time Valery.
Imagecak-close-3 by Mark Townley, on Flickr
Been thanked: 4958 times
Post by eroel »
Mark:
Beautiful session, clean and crisp images all of them.
Has thanked: 17925 times
Been thanked: 8894 times
Cracking shots Mark :bow I really enjoyed them all :hamster:
We had hail from dawn till lunch, then rain from lunch till bed. I think we were in the horrible Irish sea / Cheshire gap stream :(
Thanks everyone! The adapter plate to double stack my nice 50mm etalon onto the SM90 is scheduled to arrive tomorrow! Woohoo! Looking forward to hopefully getting some clear skies this weekend now.
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
All TOP images Mark, I find the CAK images rich in contrast.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
